Adjustable struts, how?
svt93style
Colorado Springs, CO
Michael
Slow
So I see the struts are adjustable. Is this something you have to do while on an alignment rig?
melwff
Danbury,CT
2021 Mach 1 M2486
Yes unless you have a homemade setup that can measure degrees, lots of YouTube videos.
PeteSD
San Diego
Pete
'21 Mach 1, '21 GMC 1500 Sierra, '22 BMW 540ix
Be prepared to come armed with how-to documentation... two Ford dealers I visited had no idea what I was talking about. They of course charged me to do the 6 screw removal and then re-align it to factory spec in our manual. Huge difference in handling afterward... a must-do IMO. I had way to much negative camber beforehand.
Jimmy Dean
Gonzales / Pierre Part
Al
HP or no? is there any difference in those settings between the two?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
First I've heard of this, can you explain what it is?
PeteSD
San Diego
Pete
If you have an HP look at the top of the strut towers for the screws.
actually... the strut needs to be dropped in order to see the 3 screws on top of each tower. you cannot see squat from the engine bay since the camber plate sit underneath.
below is what i marched into my dealer armed with... its for gt350, but same idea. Courtesy of "Tomster" post on this site:
https://www.mustang6g.com/forums/threads/removing-the-cftp-camber-plate-screw-pins.150085/
Ford Instructions:
https://www.mustang6g.com/forums/at...00_cftp_job2_caster_plate_lowdown-pdf.520899/
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
So if I'm understanding this correctly, if the three screws are left in place, the car aligns just like it didn't have the camber plates at all?
PeteSD
San Diego
Pete
Yes, cannot adjust front camber specs if screws are not removed. In other words...camber is fixed wherever it may fall on each particular car. Mine was about +.4 out of factory specs if left in the "fixed" position.
svt93style
svt93style
Michael
Slow
What a beating but good info. Seems like a must to get the pins out and get the alignment to factory specs. Did you set it to Track or Street specs?
