Added FP PP2
OrangCrush
2015 Mustang GT Auto 3.55 - X pipe,Roush axleback
I installed a custom tune/ngauge on my son’s car cause i was putting headers on and I was not satisfied with the tune. The shift points were messed up and couldn’t get it corrected. So I put the power pack 2 on and it was so much better. I could actually feel the difference.
lazarus870
Canada
2016 GT PP
Is this tune worth it to get out of warranty compared to others? I want it for the low end torque. Don't really plan to do any more mods.
Also is there any noted longevity concerns people are having with it? Is it any more or less reliable than a Lund or other tune?
VisceralSyn
Memphis, TN
David
2017 Ford Mustang GT
The FP tune is conservative, aftermarket tunes likely bring more power. The FP tune really is how the car should have been released stock, maybe not with the NLS stuff. But the bump in torque down low, the added power is felt when WOT from torque peak to hp peak. Neverminding rev limit being moved from 7000rpms stock to 7150rpms. And if installed by an ASE certified mechanic, or a Ford dealership it does not void the warranty. However, it's retarded easy to do it yourself.
Brazos609
2015 GT Premium PP Recaro
You used the PP2 with headers? Catted headers I assume.
OrangCrush
No, catless Stainless Works and no check engine light with O2 non foulers.
AZ18yote
Arizona
Bryan
If warranty and carb are out of the picture tuning for e85 is a much better way to go(assuming availability in your area). May as well add long tubes with the same tune revision.
rileythemustangguy
Seattle, WA
Riley
2017 GT Premium PP
I had my Power Pack 2 installed at the Ford Nationals in 2018 and LOVED it immediately. I thought I'd lost the link from MotoIQ that evaluated the Ford Performance Power Packs, but just refound it and wanted to share it so we don't lose it. PP2 gives nearly 30 hp and 30 ft-lb over the stock GT, and to me, the best part was the big kick in the low range torque!
The linked article here was huge in helping me choose Power Pack 2 for my car over Power Pack 3, thanks for bringing that back up. Car feels so much better than stock and when paired with a catback exhaust, really livens up the crackles on decel. Also, just to back up what MotoIQ found, with PP2 installed (before the catback install) I ran 405WHP/390WTQ on the dyno. Another side note, only 92 is available near me and I haven't had any issues with it. However if you only have 91 around, the ProCal software has a check box for that, a slightly revised tune to account for the decreased octane.
J17GT
IL
2017 Mustang GT PP
I had very similar results, my car put down 403 / 395. Car was otherwise completely stock including the exhaust. A 2015-2017 car went on the dyno after mine with the loudest exhaust ever and put down upper 360s. He was confused why my quiet car made such great power. 😁
dhborden
Sagamore Beach, MA, US
Doug
2021 Mach 1 Chassis# M1869, Iconic Silver
I had mine (PP2 on stock exhaust) at Summit Point for an HPDE weekend. A friend recorded video as I went down the straightaway at full throttle. When I got off the track, he was so excited, saying the car goes "whoosh" instead of roaring. When he showed me the video, it was true. I realized it's a great stealth car with the rumble inside much bigger than outside. Great way to NOT attract unwanted attention!
Shadowdriver
Shadowdriver
Houston
Eric
2016 Mustang GT 1994 Corvette 1984 Corvette 2015 Kawasaki ZX14R 2000Suzuki TLR1000
That article helped me make the same decision. I DD my car in Houston and stop n go traffic is common. Low end torque was a definite want and the upper end gains were icing on the cake as it were. Def happy with my choice, no regrets.
lazarus870
Canada
2016 GT PP
How often do you need to service or replace the air filter? And does it leak water in when it rains?
Meatball
CA
17 GT
My filter would get a little moist under the vent when it rained. I put a weighted pad over the vent whenever I parked in my driveway. Prob was unnecessary
dhborden
Doug
I've never had an issue with a wet filter even when it was parked out in the weather and only sometimes covered. I replaced the Ford paper filter with a K&N permanent filter and clean it once a year faithfully, and before the two times I took it to the track.
