Active Grille Shutter Motor / Install (AGS)
emericA243
pa
2016 Ecobeast PP
Hello all,
I've had my AGS removed on my 2016 EB to allow fitment for other mods. I'm now attempting to reinstall it and not sure if im lost a bracket or what. I have the shutters installed but i cannot figure out for the life me how how this motor attached back on in the back. Can anyone provide some insight? Im pretty mechanicaly inclined and can figure this stuff out but unless i lost a bracket or something i cannot find any possibly place where the motor would sit/attach to the back of the shutters.
At a minimum does if anyone can help me find a parts list\diagram \ installation or even can take a picture or two of theirs back behind the grill from the top, would be appreciated.
emericA243
pa
2016 Ecobeast PP
Thanks, I went through them but couldny get much farther. Here's a video where im stuck.
Kona5.0h
Illinois
Nicholas
2020 Mustang Gt
Just took mine off the actuator sat inside a bracket
Kona5.0h
Illinois
Nicholas
2020 Mustang Gt
I have a 20’ looks a bit different in the back. However that bracket that holds the shutters in place. It can be installed upside down and that looks to be your case. Theres a bolt that secures that arm. Which ties together the upper and lower shutters together off one actuator.
Like I said mine looks different it actually has two bolts that get secured into that arm.
emericA243
pa
2016 Ecobeast PP
Haha thank you so much. I literally flipped that connector arm and it all made sense.
linkysys
Seattle
2015 Mustang Ecoboost
Orientation of the connector for upper A shutter to lower B shutter shown below. The lower bolt hole is slotted. The connector has to be detached from the radiator side of the frame in order to pull the part. In order to access this, you need to remove the bottom pan, front bumper cover and the upper plastic trim. It is secured to the frame by 4 bolts and 2 large plastic panel clips.
For anyone tackling this in the future, the 2015-17 have a different shutter design than the 2018-20. I believe the actuator's for the 2018-20 are the same for the Expedition/Explorer and are sold separately. For the 2015-17, you need to buy the entire shutter assembly if your actuator fails.
Does anyone know if the complete 18-20 shutter would work in a 2015-17? Mounting is likely the same but I'm wondering if the wiring harnesses are compatible? My actuator is bad. Since Ford forces me to replace the entire shutter, I'd like to install the 18-20 if compatible so that, in the future, I can replace the actuator separately. Aftermarket shutters are readily available but I'm not sure if any include the internal motor.
Shutter is Ford FR3Z-8475-B (FR3Z-8475-A).
Actuator motor not sold separately FR3B-8476-AA (or FR3B-8476-AB).
Note that Ford parts indicates the shutter doesn't include the actuator and it's not sold separately. I called the dealership and they pulled one off the shelf and confirmed that it does have the motor installed internally. YMMV. Ford parts will refer you to their obsolete parts vendors who will tell you that the part number for the actuator ( FR3B8476AA) has never been in their system.
linkysys
Seattle
Can anybody confirm if the '18-23 grille shutter can be installed on a '15-17 Mustang? The part appears to have identical mounting. Main difference is the internal actuator on the newer iteration is sold separately in case of failure and is the same part used on F150/Explorer. Previous gen '15-17 shutter incorporates a unique actuator part not sold separately and prone to internal failure. Newer part # JR3Z-8475-F vs FR3Z-8475-B. They appear interchangeable but I have not been able to confirm that the harness/wiring are compatible.
linkysys
Seattle
To restore the car to OEM and not have DTC codes. My actuator was defective and throwing codes before I removed it from the shutter (randomly would leave the shutter closed when it needed to be open). I'd completely remove the shutter if there was a way to permanently disable the DTC's in Forscan. Since there are cold weather versions of this car sold in Canada that exclude the shutter from the factory, there is probably a way to toggle the cold weather package in Forscan, but IDK.
FYI, I have only been able to source this part (for 2015-17 Mustangs) sold separately in Europe as Ford Part 2162762, FR3B-8476-AB. It's about 95 euros. They can't ship to the USA per their license agreement and in the US you have to buy the entire shutter assembly to get the actuator ($450-800 retail). Ford does sell a separate actuator for the >2018 model. I have contacted Ford corporate attempting to source this part and no one has a clue. Ridiculous to be forced to ship a part from Europe for a car made in the USA and likely pay a tariff on the part. And we wonder why manufacturing is disappearing.
Have you tried reaching out to Mustang salvage facilities? They may be able to ship you a good used part without all the shipping hassles you mention.
