Aces IV additive/octane enhancer
Hazmat SRT
Detroit Metro
Andy
Mopars
That above was with VP100 and 3.5" pulley. This picture below is with 93 and ACES with 3.5" pulley. I realize the rpm and Boost are not equal but this illustrates what's going on.
Almost 5 degrees positive knock and 5 subtracted from the base 18.
So if I read that correctly it's giving one degree of timing retard to approximately one degree of knock detection.
This makes me wonder, in a perfect world where no knock is detected, how far the PCM and tune will go in terms of advancing timing. For example, at what point does the computer no longer add timing advance in the presence of no knock? What's the max advance the PCM will shoot for?
There's a law of diminishing return when it comes to adding timing and it would be great to know what that value is for the Coyote under boost. Based on what you're showing me, this correlates to the idea that the system is always working to adjust for maximum advance based on the knock values and pulling back when it sees some to keep the engine safe. That aligns with what Whipple is telling you guys about how their tune works.
From my perception, it's always riding the ragged edge and doing everything that it can to maximize power. This is where a custom dyno tune with HP tuners might be more helpful to find a more narrow range of values and limit spark advance. My rule when tuning was always to find the point at which light knock occurs and then back down 1-2 degrees of advance while keeping boost the same in a specific AF:R range (usually 11-11.5:1 based on the engine).
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Whipple's calibration can advance timing as far as 22 degrees without the presence of knock, if knocker is always happy. Other calibrations such as Lund I've heard may be in the 18 degree max range, but some may have more now. It's my understanding that Whipple's calibration is one of the higher calibrations for max timing.
Super Werty
AZ
2015 PP GT
So I checked my plugs... Glad I did. Edit: after doing some more research I found several other forums talking about this orange effect from octanium and torco. Some guy even took off his head and found it all over the valves. But I couldn't find a single failure and every thread out there agreed it was just mmt coating and not to worry about it.
image hosting websites
Bartly
Out West
I pulled mine after 3k miles on them with only adding an MMT additive a couple of times to probably a total of 10 gallons of gas. Looks like it starts coating them right off the bat. Would imagine mine would look like yours soon enough.
Hazmat SRT
Detroit Metro
Andy
Mopars
22 degrees max with 12-13 lbs. of boost is an awful lot to try for which explains why you guys are seeing such high RWHP. The other alternative if you don't want to mess with anything beyond 93 and fuel additives would be methanol injection.
You could even run distilled water and forego the methanol and still see great results. Even the M4 GTS comes from the factory with water injection now.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Hazmat SRT
Detroit Metro
Andy
Mopars
Found something on the web. It's a bit of a long read but it talks about some of the effects of MMT buildup on plugs.
Enjoy.
rio16
MAD_50HH
Bay Area SJ, CA
Rio
2015 Mustang GT Whippled Competition Orange
OMG close to 5 degrees of Knock :doh: can't wait to see how much i have w the 91 :brokenheart:
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
The stock tune can advance up to 10* from the base borderline table. There is a difference between 11-14 and 15+ knock sensor systems in the 15+ can determine the intensity of knock. From this it can pull a certain amount of timing. If a 15+ is reducing the knock value by 0.5* it is sensing the borderline of the fuel you are running. This is essentially as you describe with advancing till you saw knock then pulling back 1-2 * but done in real time constantly by the computer with much more precision. Tuners can gain power from the stock ignition by pushing the system closer the the borderline it can sense, but this limits the lowest octane you can run.
I should add if you are seeing positive knock values, you are below your designated borderline and the ECU assumes any knock is an intense knock event and max retard will be applied. So when some one says its acceptable to see up to 2* positive knock they are not tuning to take advantage of the knock system correctly to get optimal borderline timing.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
This is really informative, and I thank you for your input. So your saying above .5 is considered outside of borderline knock control logic which optimizes power and above that point it starts going into a very protective knock strategy effecting power. The information I got from Whipple was that 2 degrees knock or less was acceptable, is it possible Whipple's calibration is different in how it deals with borderline knock.
markmurfie
Hawaii
Mark
It is possible they use different values from the stock strategy that ford uses. Either way if the knock goes into positive numbers the ECU considers this a very big problem and aggressively limits ignition performance. The system pushing up the timing until knock the ECU knows why the knock is happening. If it sees too much knock or too intense it will slow down the advance or pull as appropriate. Any other time there's knock where there shouldnt be and while it's not doing this it goes to aggressive knock reduction mode.
RockStang
AA county MD
Joe
2016 GT Whippled
I will just add that if I get even .5 knock my PBD tune starts pulling timing. Ken does not appear to allow the tune to add timing though. It's capped at whatever he sets it to. I cannot see -knock values with his tune. Unless it's something with the SCT config
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
I reached out to Whipple again asking further about their borderline knock threshold, and at what knock value it starts reducing knock aggressively. I'll LUK when I get a response.
Hazmat SRT
Detroit Metro
Andy
Mopars
This is one of the advantages of a custom tune in that it's not seeking a moving target and only reacting to knock in order to limit ignition advance. It sets a safe max limit and allows you to fuel tune without having to worry that it's always riding the ragged edge.
I'd feel much safer with something like this...
Thanks for the info.
