sdskinner73
- Dec 26, 2020
- Indiana, United States
- Shawn
- 2018 premium GT A10 3.55s
I took notes as soon as I could after this happened. This is my second 10 speed. First one had 3.15 gears and never once had an issue. The current car is a 3.55 car with the A10. Threads I’m finding are specifically for track use.
I was cruising and switched to S+ mode from normal, then went WOT.
At about 130, the car started sending smoke out the back. Not a lot, but noticeable. So I checked the gauges after I slowed down and came to a stop. Results below. It was a hot day (92F). From what I’ve read, the trans temp is inferred from the rear diff(?). Really annoying since the coyotes strong point is pulling in the higher speeds and this has happened twice now. Is there something wrong with this trans? I have a lifetime powertrain warranty on it, but I can’t exactly take it in and say it smokes at 130 either. Not sure what route to go next. Future goals for next year were a tune and some basic stuff, with ESS down the line. This needs fixed before I do any of that, of course.
Cylinder head temp jumps from about 205to 210 somewhere up to about 212.
Inlet air temp went from about 98 to 112.
Engine oil pressure said normal.
engine oil temp normal.
trans. Oil temp jumped all the way up to about 235.
voltage never really changed much vacuum never changed much.
I suspect the trans is getting too hot and that’s what’s causing the smoking, but it only happens every at around 125-130, but not every time I’ve done this.
Just got oil changed that day, about 70 miles prior. Only mods are MBRP cat back, drop in filter K&N.
Sport plus mode. 3.55 gears. A10.
