5 Point harnesses
brfdrums
GA
Brandon
2020 GT Premium PP1w/Magna-Ride
Hello everyone,
I will be installing a couple of 5 point harnesses in my car soon(for an HPDE event at the end of May), my question is, since I'm using them with my stock seats, how should I bring the shoulder straps around my head rest? Through the middle or on each side. I've seen both but not sure which is best. I hope someone with HPDE or track experience on OEM seats can help.
Thanks!
Roadsign
2016 Mustang GT PP
First you need to check with the group(s) you plan on running with. Most will not allow the use of 5-pt or in some cases, any harness with stock seats. The recaro's are allowed to use a harness in most cases but it will have to be something like the schroth with the anti-sub tech. Not sure what other brands offer this. I'm not aware of any group that allows a 5-pt with any sort of stock seat but someone here may have more info.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I mean, they arent intended to be used with stock seats for a number of reasons. The anti submarining crotch strap is one, the soft top stock seats shoulders are another. Under belt tension the seat tops compress down, which can then compress your spine (which is Bad)
Belts are part of a safety system.
* 5-point + rigid fixed back race seats (with sub strap and shoulder strap holes) + harness bar + airbag delete + helmet + hans device
Versus
* OEM 3 point belts + airbags + generally no helmet
What HPDE requires a 5 point harness? Thats unusual for a novice group.
brfdrums
brfdrums
GA
Brandon
Versus
I'm aware of all that goes into using a 5 point harness. I will be using the Sub part of that harness as well. However, due to budget reasons and more important bills I can't afford seats just yet and I can't afford a harness bar. So, the instructor I will be riding with said a 5P would be a good start. And the HPDE is not requiring me to have the harness. It is the first step in building out my car.
So with that, you didn't answer the question. You simply stated stuff I already know. So with that said, even though it isn't ideal, which would be better?
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
1 old racer
Fontana CA
Will
something you should consider. A 4 and 5 point harness will keep you in a locked position. which means that in a forward hit your head will move a lot more than your body. That is how neck injuries happen. So if you are going to use a 4 or 5 point system then you should use a neck support device. Also because are locked in a upright position that will be a real issue in the event of a roll over. Your body will stay in a upright position with the possibility of the roof coming down to visit you. That will become a big issue if you don't have a roll bar. So with all that, let me sum it up. Use the factory belts til you can get a neck support device and roll bar.
