5.0 Dyno Chart Compilation
SheepDog
Colorado
Dax
I figured it would be up there... are you getting any slip with the griptec?
None at all. It works great. I wouldn't be able to run a standard pulley this small with the 6 rib setup. This pulley at sea level would be making somewhere around 16 psi give or take. But up here, Im maxing out the blower speed at 7,500 rpm engine speed, just to make 12.8 psi. Probably should have gone with a D1x, but its plenty fast for a street car.
Bmaughan
Az
Ben
2015 procharged mustang gt
That’s good to know... I’m only at about 1200 ft but my 3.4” pulley is only making about 11lbs. I’m thinking it has to be belt slip.
SheepDog
Colorado
Dax
Yeah I would expect to see around 13 or so with that pulley. I'm using the Gates green belt as well. There's a lot of other variables though that contribute to measured boost pressure. You may have a small boost like somewhere and be losing one or two PSI through the system. Look around especially at the supercharger pulley for belt dust. The other advantage to a pulley like the griptech Is it you don't have to put so much tension on all of the pulleys and the belt to make it hook up.
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
2019 Bullitt. Whipple Stage 1 Whipple tune. 93 octane gas on a 91 Whipple tune.
Bahndvr
Roushcharged
Germany
'16 Roush Warrior Mustang
VMP Gen3r
809 and was still pulling when they let off
SheepDog
Colorado
Dax
VMP Gen3r
809 at the crank and was still pulling when they let off
I guess I'm not that smart, because I am not understanding your Dyno graph.
Bahndvr
Roushcharged
Germany
SheepDog
Colorado
Dax
Metric. I'm in Europe. 809hp
Yes I figured that I was referring more to the graph itself where what appears to be the torque curve has the higher number on it, and the horsepower curve has the lower number.
Bahndvr
Roushcharged
Germany
Well yes the blue is Kilowatts (horsepower) and red is Newton meters (torque). The graph goes from left (2000rpm) to right (8000rpm).
SheepDog
Colorado
Dax
good stuff, that's a great car for the Autobahn
Bahndvr
Roushcharged
Germany
GT Pony
Pacific NW
The left and right scales are different ranges. On dyno graphs, the torque curve is always flatter than the HP curve.
Bahndvr
Roushcharged
Germany
It's printed in portrait and not in landscape like most.
5.0hner
Virginia
cicioperformance.com
2017 Mustang GT
Finally got my Paxton kit installed. This shattered my expectations
Paxton 2200 SL
ID1050x
93 octane
DW 400 fuel pump w/ BaP
Kooks catless 1 7/8 lth
Ported boss manifold
Tuned by horsepower solutions
Put down 730/542
