3rd gen coyote engine cover
Elvis66
Elvis66
High Desert California
Brandon
2019 mustang GT ..2014 Camaro ..72 Chevelle ..67 LeMans..97 4runner..2001 tundra
128% looks better than the stock one. I wonder why Ford couldn't just make one like the 15-17, which looked good IMO.
Thanks man .. so I've been working on another creation and was able to get the 15-17 cover to fit ..just need to make adapter plates
Elvis66
Elvis66
Brandon
HoosierDaddy
Randy
Best guess: (a) mute the DI sounds as much as possible (b) more people like change than hate it.
boB
boB
2019 GT PP1
When I removed my engine cover to modify it I saw some thick high-density foam channels covering what I guess are the injectors, maybe to dampen the noise. With these in place would the hard plastic cover do much to further dampen the noise? I haven't noticed any more clicking / etc since removing much of the cover.
Elvis66
Elvis66
Brandon
Mostly they're just keep the engine cover itself from getting too hot.and vibration
NickBlack
Colorado
2019 Ford Mustang GT PP1
Yes they are .. version #2
@Elvis66 You're work is inspiring! Spent some time yesterday trying to retro fit those valve coil covers. I see you had to cut some holes in the coil covers to make them fit.
Do you still have the valve covers? If you're not using them since you're new set up is installed, I'd be happy to buy them.
Or is it possible you can take pics of the front and back of the coil covers? This way I'll have something to work with when I cut up mine.
Still don't know how you managed to fit the passenger side over the DI pump and connection that sticks out...not sure if you have any pics of that area after modified...would help a ton!
Thanks a million, great work!
Elvis66
Elvis66
Brandon
Hey what's going on man thank you very much for the positive feedback... So you will definitely have to do some modification work to the d I pump.. you have to take the bracket that holds the insulation off ..I had to disconnect the wiring harness that goes to it and flip it down so would have more clearance with the coil cover .also it will be a tight fit and the coil cover will be up against the insulation on the firewall but it doesn't look bad... As for the driver side to make it fit more properly you will have to cut an extra hole in the cover.for the crankcase tube.there's really no way to make them fit perfectly like they would on the 15 through 17 but they still look very nice and clean up the engine bay.I've also been working on a 15 through 17 manifold cover that I was able to get fit as well so I will have a third option for the third gen coyote as well using these coil covers.
NickBlack
Colorado
Thanks so much man, really appreciate it! Looking forward to the 15-17 manifold option - keep up the great work!
Scott.lester1
Scott
2019 Mustang GT premium, oxford white, performance package level 1, 401a
Been working on a few projects that involves dressing up the engine bays for the 18/19 .
how much would you charge to make me one of these with a race red and carbon fiber look, I have an oxford white with show stopper red interior and I think that would look pretty good to spice up the engine bay?
spydrhawk26
Pennsylvania
Miguel
2020 Mustang GT, Velocity Blue
I definitely need this in Velocity Blue. Happy to supply my stock cover from my 2020 for parts. What would this run me?
RazzaRossa
West Coast of Florida
Ron
2019 Mustang 6spd GT Premium PP1
I changed out my stock engine cover for the much smaller Bullit style covers. Mainly so I could get to the friggin' dip stick, and I wanted to see more of the intake runners. They are plain black molded plastic, no detail at all to them. You've inspired me to do them up. Race Red with black lettering to go with my color scheme. I like the yellow coolant tank on yours. I'm not sure if RR would work in my mind/taste, red/black theme again. I guess try it plain black anodized, then I could always paint it RR.
Nice work by the way. I use to live in the "High Desert" back in the '80's when Palmdale was a boom town. I hated the drive to the Valley everyday, one of the reasons I left.
Elvis67
Brandon
19gt ..19 ss 72 chevelle
I hate Palmdale road ,Horrible two lane .I think the gloss black coolant tank would look the best with the direction you are going .
