3.8 Whipple vs Stock Engine Dyno
Autopart101
Joe
2020 GT
After fixing a fuel line leak. I decided to install a GripTech 3.25 pulley and make some pulls. Not sure how long the stock Short block will last @1045WHP. Not sure of the boost level as the sensor on the dyno is out of service right now. Car gained almost 100WHP from the 3.50 to 3.25 pulley. Thanks to @DRP Motorsports for the tunning revisions and fast service as always.
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
If you datalogged the pull, just back barometric pressure out of your manifold absolute pressure to get boost. For example, if manifold is 34.7 psi and atmospheric is 14.7, then boost is 20 psi. Yes, I picked easy numbers to work with lol.
Great numbers for a stock block! Thoughts and prayers for your pistons šŸ˜‚
Mach1Racer
Everywhere
Mach 1
Hey, what did DRP say was the limit they thought you should stop Aton the STOCK Gen 3 Coyote engine.
This is an awesome setup. I see guys with turbos pushing 1050rwhp in stock bottom ends but don’t see too many supercharger cars doing this.
Autopart101
Autopart101
Joe
2020 GT
DPR and Finishlines think Im skating on Thin Ice. Already shopping for Short Blocks. Plans is 10 rib set up and more boost next year.
Mach1Racer
Everywhere
Mach 1
What do they think is acceptable? 850, 900, 950, what?
engineermike
La
2018 GTPP A10
I’d like to know what it will actually hold as long as the tuning, rev limit, and fuel system have everything well controlled. I know drp tends to keep the timing a little conservative which helps manage cylinder pressure.
Mach1Racer
Everywhere
Mach 1
Yes, I would like to know because I’m thinking of turn mine up as well.
EngineerMike, what your car holding right now? (RWHP)
Mach1Racer
Everywhere
Mach 1
Your guess is literally as good as mine. Local dyno shop shut down. Whipple 3.0, 3.0 pulley (~18 psi), 21 deg timing, etc. I’m logging around 100-105 lb/min airflow.
must be 9xx rwhp
Autopart101
Autopart101
Joe
2020 GT
HKusp
Hampton, Md.
Jason
must be 9xx rwhp
I would say easily that based on that lb/min consumption. A good rule of thumb is 10whp per lb/min. I know there are a lot of factors that go into it, but I would say it's a pretty safe bet at those numbers, Mike would dyno at least 950whp.
Mach1Racer
Everywhere
Mach 1
950 seemed to be the point no one wanted to pass without my ok.
Ok, this is what I wanted to know because I’m looking to turn up the wick a little bit and I have not found a general consensus listed in any articles I could find.
I constantly see these TwinTurbo guy pushing 16psi and making 1000+rwhp on stock engine but most Supercharger guys seem to stay 650-850rwhp.
robvas
MI
2011 GT
No reason to stay at only 650-700 unless you're limited by pump gas
Remember that turbos are more efficient than superchargers so they are going to making more power either way.
