3,000 RPM Limit
2007GT500
Ohio
2022 GT500 and 2025 Z06
I just hit a little over 100 miles and still getting the limit at 3,000 rpms. When does this stop happening so I can drive the car hard which is the reason I bought the car. There is a yellow line on the tach at 3,000 rpms and the shift light beeps over 3,000 rpms. I set the audible tone in settings but I thought it was going to go off at 7,500 not 3,000.
gfcobra04
Conroe
Gary
2000 Cobra R, 94 Lightning, 2020 GT500
You adjusted that with the cobra button. You raise or lower the shift point.
oregongt350
Oregon
Michael
2022 GT500 HE, 1967GT Fastback S code,
Has nothing to do with engine break in read the owners manual
Cgouzoulis
chris
None
Has this car been taken out of delivery mode?
Tomster
Beware of idiots
Tom
I don't recall mine ever having limits preset once taken out of transport mode. I was not aware that you can set rpm limits. I like the idea of that, especially if you can set it and a valet or mechanic can't undo it.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
Yep, if his car was still in TM, he would have known it without asking. <smiIe> (No offense intended, OP) Downright pigs in that mode. :-)
However, I don't think what you described (or the OP asked about,) is the issue, Tom. I think It's just to set a shift point so you can have the visible and/or audio alert. The only other RPM setting that I'm aware of is for Launch Control.
oregongt350
Oregon
Michael
Are we able to set a maximum, do not exceed rev limiter setting ???
kilobravo
Corpus Christi, TX
kilobravo.com
KB
Not to my knowlodge, Michael, the LC RPM is the only one that I know of you can set and it's a limit. But, you can set the shift point RPM just below the RL and you can have a light and tone if you reach it. Pad it a few hundred to account for your reaction time. Obviously, this only applies in Manual.
FWIW, I used it for awhile and then just got lazy and let the confuser worry about it while I have fun. <grin>
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
What I think hes looking at is the visual tach, remember you can either have the heads up display with the lights on top of the dashboard at the shift points, or you can have the digital screen and that is set @3,000 which is adjustable, i think he is just looking at that and not realizing its changeable.
