2024 recall issue
tommyd
northern new jersey
Tom
2024 gt premium manual
Hi. So I brought my manual 2024 mustang to my Ford dealership to address the clutch line recall. After the service was performed ,as I was driving it back home, the clutch felt different. It now has some play in it, an inch or more play before I engage the clutch. I had to move my seat forward so I wouldn't stall. Is this the way it's going to be?. Thanks
SheepDog
Colorado
Dax
Probably some air trapped in the line. Pump the pedal many times ( could take dozens or a hundred) and it will eventually force the air out
Skye
≈39N
"Skye" Mach1 N2144
Geodudes550
Bakersfield, CA
Joseph
S550 2018 Mustang GT Premium
I had a new clutch put in by Ford last year and I had the same problem. Just air in the line, it went away after I spent a morning pumping it out.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
If you get a stick or 2x4 or use your imagination, if you depress the clutch pedal and lock in the down position with the stick, leave it over night most if not all the air will be out of it.
Works on motorcycles
