2020 GT500 - Retorque Wheel Lug Nuts
Snoopy49
California
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
I just checked mine today for the first time at 876 miles and all 20 lug nuts rotated.
My car has never been driven hard or done any burn outs.
Even if you drive like an old lady going to church on Sunday, make sure you check the lug nuts.
From the 2020 GT500 Owners Manual Supplement.
Retighten
the lug nuts to the specified torque at 500 mi (800 km) after any wheel disturbance (tire rotation, changing a flat tire or wheel removal).
150 ± 15 lb-ft ---- (200 ± 20) Nm
Note:
Torque specifications are for nut and bolt threads free of dirt and rust. Use only Ford recommended replacement fasteners.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
Damn good catch, Earl!
Makes me think Flat Rock didn't quite torque to spec as I don't see any other reason that they should have loosened. I'm using Terrance's Ti nuts and when I've checked, they were exactly where I set them. I have 1900 on her with three quarters of that time using these lugnuts.
Rapid Red
Woodstock GA
Greg
All 20 check torque wrench calibration ? To uniform to have just backed off.
Snoopy49
Snoopy49
California
Earl
I used a 250 lb-ft Snap-On torque wrench and it is calibrated. Not all the nuts required the same additional torque. I didn't bother to check the existing torque for each lug nut before I torqued them, but they all rotated when I applied 150 lb-ft. For all I know they may have been torqued to 135 lb-ft which would have been within the spec.
Rapid Red
Woodstock GA
Greg
Ok misunderstood the post, strange that happened.
Snoopy49
Snoopy49
California
Earl
Something prompted Ford to make mention of it in the manual. It looks like it is a one time check until the wheel has to be removed and that resets the clock.
PUR_SPD
St. Louis
Darren
2020 GT500, RR, CFTP, TP; 2013 Boss 302, SBY; 2016 F150 Super Crew; 2010 Audi A6
Either way not a bad recommendation to check them. Nope they shouldn't have loosened but you never know and it doesn't hurt.
Thanks for the friendly reminder.
Rapid Red
Woodstock GA
Greg
Read the same in mine also, looks like a standard for all.
460Fred
Wyoming
Fred
‘19 GT350 (sold)
I work with torque wrenches daily mounting wheels. I discovered this a while back and have been very pleased so far. Before you bash ICON (Harbor Freight) you might want to watch this until the end.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
It has always been recommended practice to recheck torque on lugs after 50-100 miles of driving any time the lug nuts have been removed.
