2020 Bullitt Build
s550.bullitt
Chicago
Tyler
2020 Mustang Bullitt
Overall end goal mid to high 800s low 900hp to the wheel. With Paxton blower and bolt ons
looking for drive train upgrades what would yall recommend?
my original Thoughts mantic twin disk or McLeod RXT twin disk
Calimer D4 stage 2 MT-82 trans
QA1 carbon drive shaft
DSS half shafts 1500+hp
Viking street / strip shock set up
Full BMR adjustable suspension
s550.bullitt
s550.bullitt
Chicago
Tyler
Sounds good. What fuel system? I’m going for 850 whp myself.
Most likely just going to run a boost a pump with ID1050X until I get fueling issues. Then I’ll upgrade the pumps at that point. Keep running 93 with a mixture of 100 so don’t need to worry like I would with E85
19BULLITTwhipple
California
Ramzi
Bullitt 2019
I was thinking of adding race gas but 100 octane is expensive 😅
NGOT8R
Adrian
2019 Bullitt
Is your car a magneride or non magneride? If MR, just wondering how you plan to get around that to run Viking shocks? I’ve heard that many tuners won’t tune boosted cars on a BAP and will require a fuel system.
s550.bullitt
s550.bullitt
Chicago
Tyler
Yeah it is MR, still looking into how to get around it I know people have done it trying to find the best way to go about it still. Viking shocks are not a must have although it would be nice
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Is the idea that MR can't handle the power?
I'd think that Ford Performance's MR upgrade kit it would be just fine, in addition to a lot of Steeda/BMR subframe & suspension mods.
Unless you're looking for ultimate drag-racing application.
s550.bullitt
s550.bullitt
Chicago
Tyler
Didn’t think about the upgrade kit route. Makes the most sense. But yeah not a crazy drag build still will drive around like normal
Too. Thanks!
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Too. Thanks!
If you would allow me to help.
It's not just the suspension itself that needs help. Both front and rear, the subframe connections to the unit body are......hysterically bad. Ridiculously bad. So bad they don't allow the suspension to properly do it's job. And has the shocks and struts acting as semi-stressed suspension links, rather than strictly controlling up & down body movement.
Both Steeda and BMR have kits to better center/locate/secure both subframes, and they make a world of difference. The rear/IRS in particular.
I consider the Steeda mods in my sig-line the bare minimum, and would think those mods in conjunction with the FP MR upgrade kits (springs, sway-bars, software) would handle 1000 HP easily.
NGOT8R
Adrian
2019 Bullitt
As far as tuning a SC car with a BAP, it can be done, but if ai recall, one of Lund’s tuners Alejandro Flores said they don’t trust the end user to do right on their end.
s550.bullitt
s550.bullitt
Chicago
Tyler
Yeah I 100% am doing full BMR suspension on the car, k member, bushing, front rear end links, sway bars. Makes a huge difference in these cars
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Is your car already lowered? Looks like it.
vanquishvzla
Jacksonville - FL
2015 Mustang GT 50th anniversary
that power level on a BAP is just a timing bomb... you are gonna spend a shit ton of money just to save some on your fuel delivery system??? no thank you...
