2016 GT flashing check engine light....
Bigred911s
Big Red
today while driving home from work on the highway the check engine light started flashing. I was driving normal at highway speed. Had just under 1/4 tank of gas. Light went off after about 5 mins. Went home for about an hour then got back into car to go get gas. Staterted the car after filling tank with premium no check engine light.
The car has the Lund premium gas tune and it's an auto tans. Tune has been on the car for about 20k mi with no issues. Car has 45k on it now and still has original plugs.
Any ideas what caused the check engine to flash? Noticed idle was a little rough when cel was flashing.
Shifting_Gears
South Florida
Had a similar issue except mine wasn’t flashing. There’s definitely some light misifiring under partial throttle or cruising. A little research lead me to think it’s bad IMRC plates in the intake manifold. Haven’t taken it to the dealer yet for a diagnosis but it’s worth considering.
Can you pull the code with your tuner? Mine was a P0308 cyl 8 misfire.
Bigred911s
Bigred911s
Big Red
I’ll try pulling code with my tuner and let you know. But the issue is gone now. Car pulls strong now not flashing cel.
swooshdave
Portland, OR
2019 Mustang GT Premium
On some cars the code is stored for at least a couple restarts. Maybe it’s longer with newer cars where data storage is less of a concern.
Fetlock
San Diego
Brian
2018 GT MT
Usually a flashing cel means a real time misfire and unburned gas is getting through to the catalytic converters.
Bigred911s
Bigred911s
Big Red
Used my NGauge to check for codes and there were none. Car is running great with no repeat of flashing cel.
Mr. Met
06 Time Person ofthe Year
NYC
JJ
2020 GTPP Premium, 2015 GT Premium, 1999 Expedition EB
I had always been told a flashing check engine light meant you should immediately stop driving or damage is likely. Is that not the case?
HeelToeHero
Ontario
17 GT PP, 23 Elantra n-line
See above comment about active missfire and unburnt fuel entering the cats. That's always a good way to damage them.
So yes, generally that's a pull over issue as soon as it is safe.
Tbird232ci
2018 Mustang GT PP1
I don't have much experience with these cars yet, but when I was in the Shelby Dodge scene, tuners would have the check engine light flash if a certain amount of detonation was detected. Maybe Lund does something like this?
Bigred911s
Bigred911s
Big Red
That im not aware of. So maybe the flashing cel is due to some detonation / lean condition and doesn't log a code?
