2015 Mustang GT Water leaking in CAI
stockyote
College Station
Lucas
2015 Mustang GT
So basically whenever it storms or I drive through rain water leaks from vent in hood to cai. Eventually resulting in messing with the MAF sensor causing the car to be un drivable until sensor I dry out the intake and clean the iat sensor. I have Airaid Cai and I do have the hood blanket removed. I know other people that run that same setup and don’t have the same issues i’m running into. Any suggestions on how to better counteract this or fixes?
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Vent in hood?
May haps you can share what you mean by that? Maybe a picture or something.
Jackson1320
California
Jaxson
2015 mustang gt
You are supposed to have a plate that bolts on the underside of the hood to direct water away from vital parts. the plate still allows air to flow but stops water
cmxPPL219
Toronto, Canada
Eric
2019 Mustang GT PP2
Not sure if you've modified the pad/isolator on the opposite side of the hood, like Jaxson mentioned above, but depending on how much water is entering, you can try these intake filter hydro shields if you haven't heard of them before:
Screenshot_2021-05-02 Injen_Hydroshield_installed_821365c3-76eb-4822-9ece-afe20dd34037 jpg (WE...png
They're not going to prevent injestion of an instantaneous dump of water, but the micro netting prevents a some amount for cars that see rain and weather, adding a slight layer of security. You just have to find the right size for your filter, at the various brands that sell them.
So basically whenever it storms or I drive through rain water leaks from vent in hood to cai. Eventually resulting in messing with the IAT sensor causing the car to be un drivable until sensor I dry out the intake and clean the iat sensor. I have Airaid Cai and I do have the hood blanket removed. I know other people that run that same setup and don’t have the same issues i’m running into. Any suggestions on how to better counteract this or fixes?
Doesn't the Airaid CAI have a plexi cover on it - as most I’ve seen do... ?.
moses19
California
Moses
2015 Mustang GT Premium PP
I would imagine it is because you removed your hood blanket. I run the PP2 with the Shelby CAI and have zero problems over almost 2 yrs
stockyote
College Station
Lucas
2015 Mustang GT
Yes but i use it without the cover. I prefer own air box and the looks of the box with the cover is ugly imo. But people run open air box jlts all the time and have no problem with water getting into intake enough to where it throws the MAF sensor and have to end up drying the whole air box/ sensor out every time it rains lol. I might end up just switching to JLT as their gains are consistently better than air raid and I haven’t heard any issues with water and the JLT
stockyote
College Station
Lucas
2015 Mustang GT
Thank you! This could help i’ve seen threads of people putting actually metal shields over the airbox and it looks so awful. Thanks for the help hopefully this works!
