2015 Mustang EPA DATA!!!! for most models.... UPDATE 2 ALL MODELS
e30og
MD
'19 Genesis G70 3.3T Sport
It says on the website it is based on regular gasoline, not premium. So I guess that part of the performance doesn't decrease if using regular gas. Ford suggest using premium to get the best performance by HP and torque?...Nonetheless I'm relieved I don't need premium gas to achieve the MPG numbers. That would have been a downgrade from the 2014 models.
Props for clarifying, that's great news it's on regular gas!
the last mustang V6 came standard with 2.73 rear axle ratio and the new one is a 3.15. That plus emissions and maybe less aggressive advertised mileage (for all models) might explain where the lost mileage went.
no matter what it ALL depends on how one drives, period
RocketGuy3
2021 Mach 1 6MT, 2025 Cayman GT4 RS, 2025 RS3
I'm surprised the GT is actually LESS efficient than the outgoing model... Is it because of new EPA standards?
Also, the OP lists "regular" gasoline. Does that mean we no longer are required to use premium to achieve either Ford's power figures or these EPA estimates? If so, that certainly lessens the sting of the slightly disappointing numbers here.
RocketGuy3
Ah, I missed that. OK, if they're still claiming that premium is needed to achieve peak HP, then that means premium gas will also get you better mileage than what they're listing here. With premium, you would probably see numbers on the GT, for example, that were at *least* as good as last gen.
STex
South Texas
67,69 ram air and 72 GTO
I read this in another article( comment post on left lane article), not sure of accuracy,:
The V6 HP drop is due to a redesigned intake manifold in order to fit the new lowered hood. As for the MPG drops, these are due to the ratings being taken with each engines/transmission upgraded gear ratios. The GT manual is now rated with its 3.73 gears and the automatic is rated with its 3.55 option instead of the original 3.31 and 3.15. Same thing for the V6 as well.
Seabee1973
Denton, TX
Brandon
2015 Mustang GT Premium/PP and 2006 F150 FX4
How it's it less effecient with a gain of 35 hp and a small gain in weight with only 1mpg drop even if rated with the 3.73. It's pretty damn good the way i see it especially being a v8
1320'
Medford,Oregon
2011 Avenger...sadly
....35hp gain?
420 <435=15hp delta...not 35.
Tim Hilliard
Happy Owner
Boston
'15 Guard 300A PP Recaro
:thumbsup:
I also believe from what I have read in this thread the EPA data is based on 87. Every vehicle I have ever driven has gotten much better mileage with 93 whether it was an Escort, Mark 8 or a new Jeep. Everyone jumped down my throat saying that octane doesn't effect mileage but this is calculated with a calculator using the same pump.
Again, in my personal experience with today's crappy gasoline that is very inconsistent I always run 93 and I plan on running a good fuel octane booster because I have no faith in what is coming out of the pump.
My friend burnt up his 03 Cobra running 93-94, it only takes one bad batch. He runs additives all the time now, it was a $10K lesson for him. He had a mild tune (not on the edge)
Also an engine builder friend of mine just posted pictures of pistons he pulled out of a "Ford" race engine with 40 hours on them. They look brand new, runnning leaded race fuel. When this car ran in ALMS with E85 the results were not so pretty. ---- so slightly off topic but I'm getting a 435HP V8 for $34K, it's getting expensive gas and expensive additives. I wouldn't have bought the car if I couldn't afford the gas :shrug:
likeaboss
Baltimore, MD
2020 Corvette Z51
:thumbsup:
My 14 Escape 2.0 Eco is the exact opposite. I get worse gas mileage with 93 than I do with 87.
geokots
Greater Toronto Area
George
2015 Magnetic Mustang EB Premium
Sorry if this has been answered.
1. Does the S550 adjust immediately to the octane level? I drive 120klm per day and I'm thinking of using 87 during the week. I'm stuck in stop and go traffic during that time do optimal power is useless.
2. Will switching to 94 on weekends if switches immediately. I'll have to consider how much 87 is still in the tank.
3. I don't know the HP at 87 but for discussion let's say it's 290. If 93 get 310 and 87 get 290 will it adjust in between where 91 gets 300?
RocketGuy3
It gained 15 hp, not 35.
That said, if this is with regular gasoline, I'm sure premium gas MPG will be better by at least a small (but measurable) margin, in which case, I can't really complain.
Seabee1973
Denton, TX
Brandon
:thumbsup:
Exactly.... the case with my truck, I can run higher octane but to gain the benefits you will actually have to run it a couple tanks to allow the ecu to adjust to the fuel... many people think that just switching the fuel it will be better this they complain that they got even worse mpg... even my truck it got worse but I only put one tank of it in but 89 octane then the fuel prices jumped again... even then though, the 5.4 recommended fuel is 87 if I remember correctly... it would not make that much diffe re nce using the higher octane except for the cleaner running aspect of it. It takes as much as 500 miles for the ecu to make adjustments to a change of fuel, fuel ratios, maf sensors... so actually, some days might be shitty, other days good ... an ambient temperature year round would be best but that will never happen around here
geokots
George
I don't know if that's the case with direct injection motors. I believe they may adjust on the fly.
Seabee1973
Denton, TX
Brandon
I meant 15... had 35 stuck in my head because of the 435..lol but still 15 gain is still good
Seabee1973
Denton, TX
Brandon
That is incorrect.... the ecu still uses the maf sensors, temperature, barometric pressure and overall efficiency of the fuel along with the o2 sensor... with all this, the ecu will adjust fuel metering and also air to allow for a more efficient fuel burn.... if it gets a bit rich, the o2 sensors pick that up and then the ecu adjusts accordingly.... it will never be on the fly
