1st Mods on 2020 GT500
gfcobra04
Posts
354
Conroe
Gary
2000 Cobra R, 94 Lightning, 2020 GT500
The little things......
Better not leave those on the car when you take it to discount tire or equivalent. Something else will be on there and they’ll say the caps were lost. Or 2 out of the 4 will still be there and you’ll have black caps on the other valve stems.
protraxduner
Posts
819
OK
2020 Shelby GT500 Race Red
Strokerswild
Shallow and Pedantic
Posts
4,417
Southern MN
Stuff With Wheels
These are metal which some people have issues with ..... I have never cared.
They're a potential issue for those driving their cars in inclement weather, and/or in states which use chemicals on the roads in winter. In these cases, they tend to form a permanent bond to the brass valve stem when their owner least expects it, requiring eventual removal and replacement of said stems on all four wheels. Don't ask how I know....
protraxduner
Posts
819
OK
Some details. Custom domed Cobra emblems for my BC Forged center caps and for my Shelby aluminum engine cap set. Will post pictures once i put them on.
Epiphany
Posts
5,776
Global
I like to disassemble things.
Nice!
biminiLX
Posts
257
Sylvania OH
2014 GT500 and a few others
Very nice. I’ve always liked those subtle mods that really make a big difference as part of a package. OEM style center caps on aftermarket wheels is a perfect example.
Where did you find those? I’d like to order a set.
-J
protraxduner
Posts
819
OK
Tried not to get to crazy with 'cobras'. Put them on the wheels, coolant reservoir, and oil cap. These were made to fit the Shelby aluminum caps.
Jmeo
You said member ;)
Posts
6,700
Massachusetts
Jaime
2020 GT500, 2020 F150 Limited
I like your overlays buddy.
I noticed that you also installed the Shelby coolant tank. Is your rain tray still installed on the hood vent? After installing my Shelby aluminum tank, and the same caps you have, I noticed the cap hits the rain tray ever so slightly. It was noticeable to me because I painted the rain tray gloss black to install the snake decal from @kilobravo. I am not sure if I would have noticed, if the tray was left unpainted.
First, I had a machinist buddy of mine mill down the bottom edge of the cap to get it to sit lower, but it still hit. Then I reworked the fan shroud assembly to drop the tank lower. The top of the cap now sits at exactly the same height as the top of the stock cap, on the stock de-gas bottle. Did you notice any of this?
protraxduner
Posts
819
OK
I haven't actually installed the shelby cap yet, just test fitted, because i was not sure whether i was going to paint them or leave them silver. Now that i decided with black cobras i will leave them silver. I think the contrast is perfect.
I noticed immediately the tank didn't sit quite right onto the 500 plastic shroud. I modified accordingly so that it fell into and bottomed out on the bottom slot. Didn't get quite as invasive as you did but it sits like the stock tank now.
I also noticed the shelby cap for the coolant tank bottomed out on shelby aluminum tank. So i will machine off the bottom however much i need to, to allow the cap to tighten all the way without hitting tank.
Are you saying that after doing this it will still possibly hit rain tray? I plan to paint my rain tray so i guess i need to figure that out beforehand.
Jmeo
You said member ;)
Posts
6,700
Massachusetts
Jaime
Im saying that what I did worked, and it no longer hits. Plenty of clearance.
protraxduner
Posts
819
OK
I noticed this weekend that the JLT front strut covers are rubbing on the hood ever so slightly...both sides. So if you are running strut covers might check.
Also had to shave off about 3/16 of the bottom of the shelby cap to work on the shelby tank....you would think they would have made them compatible.
kilobravo
Posts
5,985
Corpus Christi Texas
www.kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
How much had to be milled off the cap, Tony and I completely agree, their fitment seems to leave a lot to be desired based on your experience.
Don't have the strut tower caps but thanks for the info.
protraxduner
Posts
819
OK
Basically the lower edge has to be removed, you could leave a little bit, but it was so small it became sharp so i removed it completely.
51 - American Racing Headers - 1
