19x11 Front with coilovers?
derieuz
The Young Fella'
Southeast Michigan
2015 Mustang GT PP
Has anyone fit 19x11's on the front yet with coilovers? If so what offsets did you run. I'd like to run a spacer with the MRR gt350's square stance with 305/35/19's as a track setup in the future if possible
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
At the moment it has not been done, its something Im personally working on to see if itll work. However on the M350 wheels 19x11 ET 55 youll need a good size spacer to make it work.
dausmus
Conroe, Texas
2018 Ecoboost PP
Sorry to bring this back. Im curious though, exactly what would be considered a good size spacer for this with the MRRs?
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
No problem
So first off I did a 19x11 recently on some forgestar Cf10 wheels and 305 tires :headbang: It was a unique application but the member pulled it off !
Now if you do the MRR wheels you will need a 25 mm adapter at min to make it work upfront. No it wont poke.
Brent Dalton
Sua Sponte
GA
2016 Mustang GT PP
What 305/35/19 tires? I run a 295/40/18 Hoosier R7 on a Apex EC7 18x10 +43 wheel in the front. The OD is close to stock and should be close to the same as the 305/35/19. I have a 12.7mm(1/2") cortex spacer to clear my aFe coilovers. Depending on what brand 305 tire, it's probably pretty close in size to the hoosier. Plus hoosiers have the bead protector that sticks out a little more. If I go any wider, I'll need to jump up to a 3/4" spacer.
No adjustment to alignment yet:
With track alignment:
