Amr 19x11 with 305 ?
TGGT
SoCal
2018 mustang gt
So I just bought some American muscle 19x11 wheels for my 19gt. I know in theory a 305 will fit, but I’m wondering if I’m screwed on the back spacing and offfset. The specs are: 19x11 backspacing 8.2” offset 2.2. If anyone has experience with these or similar rims help me out before I order the wrong tires.
sjmurphy34
Michigan
17 GT PP Magnetic
Seeing the back spacing and stuff in inches is a bit weird. It's basically a 19x11 +55 wheel if understand correctly which should fit in the rears without any issue. You probably won't fit that up front though without a spacer or rubbing.also 305s should fit perfectly on that wheel.
TGGT
TGGT
SoCal
2018 mustang gt
Thanks for the reply. I’m running 19x8.5 in the front with a 255/40 . I’m just hoping the rear will fit. I need as much tire as I can get back there
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
I'm running stock GT350 wheels with no problems but my ride height is stock.
295/35-19 front and 305/35-19 rear. Front 19 x 10.5 ET30, rear 19 x 11 ET62.
TGGT
TGGT
SoCal
2018 mustang gt
I’m stock ride height as well. I think I’ll be ok running a 305/35 or 30
NightmareMoon
2016 Mustang GT PP w/ Voodoo
If it really is a ET55, then it should be ok. Worst case a thin spacer could be used to tweak the offset.
