chagan02
All great points. No reason to add excessive weight up from. Actually I could just use the stick tires on if I got 19x9 (which is stock for a PP car I think) up front, then just gotta buy larger PZeros out back. Tires only have 7500 miles in them.Keep in mind tire weight (rotational mass far from the center of the wheel) and width adding to rolling resistance. Getting a lighter wheel then putting a bigger, heavier tire on it is counter productive. The tire affects rotational inertia even more than the wheel since ALL of its weight is far from the center of the tire. You don't really need very wide tires up front unless you're tracking it. Michelin has tire weight for every size on their website. I wouldn't go 285 up front - 265s should be more than adequate and weigh about the same as the 255s. Same thing in back - consider weight but I understand the extra width may help traction -- unless you go with a smaller diameter tire then you'll have less traction than a slightly narrower but taller tire. This is because the longer patch length on the taller tire adds square inches to the contact patch.
