160° Thermostat install instructions?
Higgs Boson
Detonation Denotation
Texas Hill Country
19 GT350R
The 160 does work my buddy just did his last week and it works perfect...I'm not interested in tossing out a new thermostat and buying a new one and doing the install again I just wanted some help to figure this one out....It will idle at normal temps and the heat is hot but when I drive they rise to 210-212 what will cause that
what will cause that is it's probably a bad thermostat. it's only a $30 dollar loss. a lot of us had the 160 with the exact same result as you and switched to the 170 and problem solved.
if someone has a 170 that runs hot its an install/burping error. i have seen like one post about a 160 that works right (outside of vendor posts, lol).
Guarded GT
Va
15 Guard GT 5.0 A6 base
Thanks for the info was just about to get one
Moetoe
Michigan
15GT
I would like to try to get this to work before I go spend more money since my mod money is very limited right now cause of buying a house
daltron
Rowing All Day
California
Jonathan
2016 GT PP
Lots of people running the 160 with no problems...I guess the same can be said about the 170 since people says their temps don't change after installing the 170...
There is a thread on here with lots of people switching from the Evenflo to the Reische and getting better temps. The Reische is a proven winner.
Lonmon
Mid East US
2018 Mustang GT 10spd Base
+1 For the Reische 170! Normally in the 180's for head temp.
5ABI VT
Gta
2015 mustang GT
Did you have the fan temps set to be on earlier?
Moetoe
Michigan
15GT
Yes I did they come on when it reads 192 the problem is my temps never go below that so my fans never turn off...I guess I'm parking the car until I can find a 170 local or get one shipped
5ABI VT
Gta
2015 mustang GT
Have you had a chance to cruise above 60- 75 mph to see if the temps will drop?
Moetoe
Michigan
15GT
Yes I did 75 in 6th for probably 20 miles and it stays around 210 but if I hit 5th they drop to around 190
Moetoe
Michigan
15GT
Do u guys think I should be ok to drive it till new Tstat comes in temps stay around 210 maybe up to 214 and fans running all the time
