Some of the shifting issues can be tied back to:Anyone have an idea if the tendency towards rough shifts in the A10 is a mechanical design issue, or a software/firmware issue?
GM also uses the A10, and I don't see as many complaints from those owners. But I know GM does its own programming for the transmission.
1) Low trans fluid level; many have checked their trans fluid level and have found that the transmissions are being installed at Ford with low fluid. This info is in first page of these thread with links and how to check.
2) Software reflash; some have claimed a simple software reflash has solved the shifting issues, while others have had it done and there’s little to no improvement.
3) Valve body failure. Most common for harsh shifts and why just a “reflash” will NOT work. See first page of this thread for more info and other links.
4) Internal clutch failure; worst failure and there has not been any correlation yet that the low fluid and failing valve bodies has attributed to this type of failure. It’s quite possible it’s just inferior parts or QC issue from when trans was assembled by the contracted vendor. Again this is on the first page with links discussing this failure.
The 10R80 issues is not affecting every S550. Plus the trans is mass produced, there’s bound to be some failures or issues.
I would suggest to anyone who has had a software reflash and the trans is still shifting bad to bring it back to the dealer and take the Shop Foreman on a drive to demo the exact issues. I would also ask them to check the valve body line pressures. A failing valve body will exhibit extremeLy higher than normal line pressures (above Ford spec). A software refash cannot fix a faulty, failing or damaged valve body.
