My mod to reduce IAT's for JLT Intake
Varekai
Mustang Enthusiast
Hernando County, FL
2018 Ecoboost
I combined mods from two different members on here to reduce IAT's, and it worked. In the morning temp difference was as low as 1 degree from outside temps, in the afternoon got as low as 3 degrees, and the IAT's didn't sky rocket while at a light or in traffic. I used some pipe heat shielding for the inside of the box and a Lexan polycarbonate sheet for the cover. Don't know if it will improve performance at all nor will I do any testing to confirm any performance gains.
GDP
2016 GT Base Deep Impact
Interesting. Seen my stock intake with IATs up to almost 200 when idling for a while in 70 degree weather after a long drive. Heat soak is a bitch.
Not sure how a stock box could be shielded from the heat.
Higgs Boson
Detonation Denotation
Texas Hill Country
19 GT350R
The heat comes from the fans blowing into the open top, that's why as soon as you move the iat goes back down close to ambient.
I bet if you just put a lid over it 99% of the idle heat soak will go away.
Varekai
Varekai
Mustang Enthusiast
Hernando County, FL
2018 Ecoboost
I didn't glue it, used some weather stripping around the inner diameter of the lid, and that just squeezes down onto the strip of the JLT box to hold it in.
Dramad1
San Diego
2015 GT, PP, Blk
Sweet I did the same a while back minus the heat shield inside the box, great idea by the way. It has been working for me with just the lid, I never get more than 4 degrees above ambient. Great lil cheap mod that works. Nice to see another give it a shot. Nice work!
Varekai
Varekai
Mustang Enthusiast
Hernando County, FL
2018 Ecoboost
Thanks! I was hoping the original person who though of this mod will chime in here.
mustang_racer
Biloxi, MS
2015 Mustang GT
I also did the top for my JLT. I also put weatherstrip on the top of it so when the hood is shut it pushes down on the weatherstrip and makes sure my homemade top is secure and snug. In addition to that, I used weatherstripping around all the openings that air can get into the filter box from the engine as best as I could.
I like your pipe heat shielding idea and I will be doing that as well.
Joe 5.0
Bermuda Triangle
2015 Mustang GT/PP
The heat soak is real with my JLT intake.
There has to be some power benefit from this due to actual "cold air" being drawn in.
Great idea, OP -- thanks for sharing!
Sheenapple
Houston
2019 Mustang GT PP2
what do they get to if you idle for about 5-10 minutes on a warm motor? my roush will get up to over 130+ so trying to see how this works
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Anybody have any MAF numbers from datalog to see if the flow rate changes with or without the top?
craigsix
overland park ks.
craig
2018 mustang gt
my black car doesnt help. i opened up 5 more honeycombs in the grill and put some foam over the top of the tube.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Anything to increase performance is OK to me. :)
craigsix
overland park ks.
craig
2018 mustang gt
you might check for water building up in the rain or check it at a car wash.
