WTF Ford and Michelin P4 are dead
Mattneedforgreen
Ky
2019 mustang gt pp1
Today I joined my wife and son for lunch and my son asked what was white on my tire. The front driver's side tire on the inside is nothing but cords. Ford dealership said it was alignment that messed it up the tire people said no way and want to do a warranty replacement but the ford dealership does not want to do the warranty inspection. Wtf the car and the tires have 14136.1 miles on them fml anything i can do.
Epiphany
Global
I like to disassemble things.
Is the car 100% stock?
1 old racer
Fontana CA
Will
The tire warranty for that tire is 30,000 miles. However if it is a staggered set up, like the PP1, you have to cut the miles in half because you cant perform the required type of tire rotation. If you take into the camber and toe setup per the Mustang PP1 specs. you got about what I would expect. I got about 10k out of my fronts when the insides were bald, not corded yet.
Hack
Minneapolis
Mustang, Challenger
If you only lightly street drive the car with no track miles your alignment is probably a little off. I would expect you might have to replace front tires somewhere between 20,000 and 25,000 miles, but they should only be down to the wear bars at that point. They shouldn't be to the cords quite so quickly. I'm a little surprised the car didn't pull on the highway or make noise.
Ronnoc
Pittsburgh
2015 Mustang GT PP
lol get used to it bud
NoVaGT
Northern Virginia
2019 PP1 GT Kona
13K miles is pretty good for MPS tires.
Just get it aligned, and get 4 new tires. I'm sure the rest of the tires are shot too.
Matco
Camarillo Ca
2019 F150 2018 Mustang GT 1996 Ford Bronco
just went thru the same thing, the toe was off, I asked if there was any damage to cause that and they said no, no damage. I then proceeded to ask if the alignment could have been off from the factory and he stated yes but as soon as I said is my warranty going to cover the cost of the alignment or 2 new tires he started back pedaling, saying there's no proof and that I could have hit something.... right after he said no damage. Also he said I should have had the first free alignment done before the 12,000 miles / 12 month period, wish they would have let me know that was even a thing... So that was the end of that, tires had 22k miles and all 4 still had 5/32nds tread left minus the 2 front inside corners were down to the cords.
Long story short out $100 for the alignment and $700 for 2 front tires
hemistar1
Hampton, VA
Tim
2019 Mustang GT PP2, 2017 F-150
Sometimes the dealer will go ahead and replace if you had car serviced there. Ford recommends every 5k to 8k ..I know a staggered setup can go from side to side but the wear could have be no caught if you had them rotate at 8k. Let us know if they will assist
RIBS
Metro Atlanta
2015 Mustang GT Ruby Red
My stock 15 burned the insides off the front tires too....lightly driven, pff from the factory.
