Wrench light advance service trac
zerolash
Huntersville
Jeff
2015 GT 91 LX
Dunno what’s causing the light. I went ahead and replaced both front abs sensors and still on. Will FORScan tell me and how to do it. Thanks
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
You need an MS-CAN compatible scan tool to see what the codes are for. But it's probably one of the rear hubs. Either the bearing is toast or an axle nut has backed off (or a sensor has just given up the ghost).
zerolash
zerolash
Huntersville
Jeff
2015 GT 91 LX
Well I pulled both rear wheels nothing out of ordinary no movement sensors looked good. No what?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
What are the trouble codes? You will need forscan or a Ford dealer to read these.
Check the harness at the air box which may also be an issue if it has become disconnected... pictured in THIS thread:
https://www.mustang6g.com/forums/threads/traction-control-fuse.109035/
Check all fuses in passenger side fuse box behind kick panel AND the under hood engine fuse/relay box for any blown or loose fuses/relays.
Seeing you have a 2015, most likely this is your issue.... for 2015-2017's the common issues with advance trac/abs/steering warning light weirdness, check the rear axle thrust washer, see here:
https://www.mustang6g.com/forums/threads/abs-advancetrac-power-steering.162475/#post-3308430
zerolash
zerolash
Huntersville
Jeff
2015 GT 91 LX
Thanks. I will check those things. As far as FORScan what scan do I do to see code? I have advanced features on there.
Is it possible there is slight damage to a rear bearing bc I just remember before I got the car the passenger rear wheel was damaged /bent. Like is said I pulled the tire and there was zero play.
K4fxd
NKY
Scan for DTC's. It will look at every module and give you the codes.
