Wow What a Difference of Opinion I see about wheel width! Opinions please read!
Returning_User
Returning_User
Virginia
Bob
California Special
I'm running the LMR R350 staggered setup (19x10 F, 19x11 R). I have Firestone Firehawk Indy 500 tires in 285/35-19 F and 325/30-19 R. My car is lowered ~1.2" and NOTHING rubs. It all fits.
Some will say (and I agree) that the 325 tires on the 19x11s is a little excessive. The tires do not look pinched on the wheels. The sidewalls look nice and straight/flush with the wheels. No poke either. The reason I went with the 325s in the back was mostly aesthetic. I really like the look of them. 305's will likely do the same job, but I have to say "power on" rear grip is really good. with this setup.
Pictures??
DemonGT
Wisconsin
1991 Mustang GT, 2021 Mustang GT PP1
Would a 275/40 be a better option for a stock height car. I do not plan on ever lowering it and the 275's are cheaper?
SBR70.3
Edmond, OK
16 Mustang GT Premium, 23 Explorer ST, 19 GTI (DD)
I had the same issue with Discount Tire. I have a 2016 GT on Steeda dual rate springs. Was running 20x9 AR924's with 275/35/20 General G-Max RS's on it. No issues there except I needed more grip when I put my Procharger on. I tried ordering the same wheels in 20 x 10.5 (45mm offset) and 305/35/20 tires for the rear. Their online algorithm said no. Went inside my local store and the rep said yes. I also scoured the forum here to verify others have fit this size. I have no issues with rubbing.
DrZed
Canada
Cam
2021 Mustang GT PP1 M6
I have LMR's 19x10 SP2s all around, square. 275/35/19 on Ford's Track lowering suspension. Absolutely no rubbing or any adverse issues. I do plan on going 285/35 or maybe a 40 series.
m3incorp
Georgia/Colorado
James
2019 Mustang GT Premium with Roush Phase 2, 2017 Corvette Z06, 2018 Subaru WRX, 2015 VW Golf, 2015 Ford Fusion
I've had a couple people ask why one car may need speedometer corrections and another doesn't when they both have on the exact same model and size aftermarket wheels and tires. You have to take into consideration what size wheels and tires were on the car from the factory. PP cars have sizes that are already larger than the base, and thus their speedometers are already adjusted for those sizes, meaning they are likely to be closer in height with a given upsized aftermarket wheel/tire combo, than a base model might be. I am sure there may be other things that make a difference also.
WD Pro
United Kingdom
Lime GT
4eternity
Craig
2019 Mustang GT
305/35/20 is 28.4 tall. 275/40/19 is 27.66 tall. That's almost 3/4 inch taller.
According to this calculator your speed would be 1.7 mph off at 65 miles per hour.
http://www.csgnetwork.com/multirpmcalc.html
I have not found that to be a problem...comparing speed to GPS, it is most always on the money...thanks for pointing that out as a point of accuracy. But but again not a big deal either way
2018S550GT
Charlotte, NC
What is the widest rear tire you can run without rubbing or a lot of poke? I would like to go with the 19x10 + 19x11 wheel combo with 285/305 or maybe 315 but since this is a purchase I cannot return, I don't want to get burned.
Opinions please! Facts are even better!
Thanks!
They'll be fine. I run SVE SP2 wheels - 19x10 285/35 fronts and 19x11 325/30 rears, car is lowered on Steeda progressive sport springs.
tj@steeda
Timothy
Looks incredible!
MCS
SW Ontario
Michael
2021 GT Premium
285/35 19 will not rub on the front...even with a lowered car.
305/35 19 will not rub on the rear....even with a lowered car.
I second this.
Check out my sig for the deets but I'm running a mild drop (0.5") and 19" rims with 305 in the back although I'm only running 275 in the front.
dtheo
Nebraska
Buyer
What is the rear camber you have on this?
Returning_User
Returning_User
Virginia
Bob
California Special
Aaarrg I got the wheels mounted but LMR sent me the wrong damn lug nuts. These need to be narrow because the factory lug nuts are too damn wide. What lug nuts are you running with your setup here?
Semp1
Valhalla
2018 Mustang GT PP1 Magneride
285/35R19 is the appropriate size for 19x10 in the front and 305/35R19 or 315/30R19 or even 325 is the appropriate size for 19x11 in the rear. I have SVE SP2 with that fitment front and rear and I am lowered with ford performance lowering springs for magneride which is .78in drop and I have zero issues with rubbing all around and 285 fills the fender out perfectly and looks perfect on a 19x10.
shogun32
Northern VA
Gorilla for lug nuts accept no other
