too tall IMO, stick with 275/35/20Hows 275 40 r20 run squared?
What are the draw backs? I'm not very knowledgeable of this kinda thing.too tall IMO, stick with 275/35/20
40 profile fronts will rub when you turn the steering wheel as well. Doable for the rear, but front has to be a 35 profile.
In what sense? whats why were here to help.What are the draw backs? I'm not very knowledgeable of this kinda thing.
I just don't really understand why the tire setup would be too tall. I understand body roll is an issue but only at high speed cornering.In what sense? whats why were here to help.
Lets do this if I may, lets take a look at ODI just don't really understand why the tire setup would be too tall. I understand body roll is an issue but only at high speed cornering.
I have taken your advice into consideration and will probably be doing a 275/40 19 setup on my GT PP wheels. Is there anything I should be considering about this? My wheels are staggered obviously, do I need two different tire sizes or am I safe with my size?Lets do this if I may, lets take a look at OD
Common setups upfront
275/40/19 OD 27.7"
275/40/20 OD 28.7"
275/35/20 OD 27.6"
So a 275/40/20 is 1" taller upfront then say a comparable 19" its also 1" taller then the recommended 275/35/20
This additional height causes your OD to be off causing suspension variance and also as I know rubbing upfront when you fully lock your steering wheel.
You can keep them the same all around you just cannot rotate because the wheels are staggeredI have taken your advice into consideration and will probably be doing a 275/40 19 setup on my GT PP wheels. Is there anything I should be considering about this? My wheels are staggered obviously, do I need two different tire sizes or am I safe with my size?
Sorry somehow just saw your reply, they were $252 per tire on tirerack, got them for $330/tire installed.What was the price on those? I'm trying to find quality for under 1k. Seems like everyone is charging out the ass.
solid price.Sorry somehow just saw your reply, they were $252 per tire on tirerack, got them for $330/tire installed.
255/40/19 but yes you can.Can you run 255/45/19 on the PP wheels? Square set up!?
whats their reason?I've been to two local places and everybody says I can't do a square set up...ugh
