Windows popping out/gap/wind noise
eian6003
Michigan
2020 Mustang GT Manual
My two windows, driver side and passenger have a gap at the top back corner, they’re at the edge of the door seal and the windows can be pushed in manually to “fix” them.
How do I fix this?
SHOdaddy68
Washington State
Daryl
2015 GT PP Premium w/Recaro
Do they automatically drop down a tad when you open the doors? If not, they probably need to be reprogrammed.
TonyT930
Philadelphia, Pa.
Tony
Disconnect the negative terminal on the battery.
eian6003
Michigan
They do drop down; I meant the window isn’t flush with the trim, and has a gap at the corner. If you’re in the car and look towards the back of the window, you’ll see a hole. Kind of like the window is being peeled back.
ORRadtech
Atlanta, Georgia
Pictures might help us understand what you have going on.
Off hand it could be a number of things. A misaligned door, a problem with the window track, a weatherstripping problem, etc.
Just guessing here without at least a few photos.
eian6003
Michigan
SHOdaddy68
Washington State
Daryl
Looks like the internal window stops need to be adjusted. The rear stop appears to be too high. Any body shop can do this for you and re-set the position sensors.
eian6003
Michigan
Question though, the rear and front stops just adjust how high and low the window is; but this problem is where the window is coming out, it's not vertical or horizontal; but forward and backward.
SHOdaddy68
Washington State
Daryl
If the rear stopper is dropped a small amount it will even up that gap at the rear of the glass. There is probably a little adjustment in the vertical tracks too.
Skye
≈39N
"Skye" Mach1 N2144
Hi @Cobra Jet,
Thank You for the procedure. :thumbsup: I've stitched those jpegs into one document and posted it here.
alilan
Dallas/Houston
Ilan
2022 Mustang GT
I am having similar problems after I got my window replaced. Did you end up getting it right? Did anything specific help you fix the issue?
