Windown Louver repaint
tuanntrang
Houston,TX
Tuan
2019 Mustang Ecoboost
Hey folks,
So for those who new to the "spray can", if you purchase a matte black window louver for your s550, how do you properly clear coat it to the shine glossy finish?
I thought a matte black would look good on my ruby red s550 but it doesn't give that pop.
any idea on what type of spray can i cna get at my
local autozone/oreilly that can bring the gloss? and how do get that matte to gloss finish?
BrakeFade
DFW, TX
E39 M5, '21 CFTP GT500
Is it common to use a spray can for louvers? If you're going to do that, clean it up real good with IPA and then paint it with gloss black spray. Krylon Fusion doesn't need a primer, is flexible enough to bond to plastic, and holds real well to the elements. That's what I would use but I've never done louvers.
Therealmattlex
Mn
2015 mustang gt
I would recommend something like Spraymax 2k clear coat. It's not the cheapest but as far as rattle cans go it can give a nice top coat. I used it on a custom painted helmet.
broncoboy22
Laker Land
2022 Bronco Badlands
Agree with just repainting it gloss black vs just trying to add clear on. You’re guaranteed to get the finish you want that way vs just adding clear on if there are imperfections in the surface now that will be sealed in
John S
Novi, Michigan
2022 Mach 1 HP
If you decide on Spraymax 2K clear (amazing stuff from a spray can) or any other type of 2K product containing isocyanates, be careful to protect your lungs and eyes.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I will advise the contrary view. I have had good luck with gloss clear over even flat black. In fact I think it is easier for gloss to self level than for black paint.
T Fades
CA
2023 GT 6spd active exhaust
I suggest do it right. This isn't a '95 civic we're talking about...
Go to an automotive paint store. Get their gloss black spray paint, with several thin coats with wet sanding in between, then a couple of thin coats of 2k clear with more sanding in between.
detamble13
Chatham, ON
2011 Camaro SS LS3
The absolute best way to paint window louvers is to hold them over a garbage can. Quickly release your grip and watch gravity do its job sending them into the can at 32 ft/s². Repeat for all window louvers you own.
