Whipple Fuel Trims
SVT-DADDY
World's heaviest S550
CT
2015 GT Convertible
That's more than questionable. I'd say its guilty!
Which fitting is it?
stang17
stang17
Wilkes Barre, PA
2017 GT Premium PP
Driver side on the manifold close to the supercharger inlet/throttle body.
In the picture below- right where the play button arrow is.
keltymd
Murfreesboro
2017 PP
that is the line that feeds the bypass actuator. if it is leaking you will go into boost too early and will run like crap
RockStang
AA county MD
Joe
2016 GT Whippled
Yep that’s the line I was referring to. I didn’t like it from day one and immediately replaced it with a heavier duty line and clamped it on both end.
stang17
stang17
Wilkes Barre, PA
2017 GT Premium PP
As always, Dustin is coming through for me and shipping me a new hose made out of Viton.
Hopefully between fixing the exhaust leak tomorrow and swapping out the hose when it arrives, I'll be cured.
I'll keep you guys posted and thank you once again for all the help!
DavidHuff
Salem,OR
That line is a bitch because you will have to disconnect the air intake and remove the throttle body to replace that vacuum line.
stang17
stang17
Wilkes Barre, PA
2017 GT Premium PP
So Dustin sent me a new fitting. Vacuum still reads about the same, but car runs and idles noticeably better. I still have a small exhaust leak I'm trying to hunt down, but making progress.
Below is a better picture of the fitting I replaced.
Tomlouns
NY
2015 Mustang GT Convertible
What is the name of that part? My installer never installed that and I have a large vacuum leak I am trying to track down... this looks like a great place to start .
DavidHuff
Salem,OR
Check all your vacuum lines to the intake manifold and the one under the throttle body.
Ruiner46
Colorado
2016 CO GT PP
Whipple changed that connection on later kits. They replaced it with a 90 degree metal fitting in the manifold and a straight hose.
Tomlouns
NY
I see that now and Thank you ... I did find my leak... it was this...
DavidHuff
Salem,OR
That has been a common mistake by some installers.
Great you found your leak.
