Battling Erratic Fuel Trims
brandonalberd
brandonalberd
Dickson, TN
Magnetic S550
Alright man. I'll look into it. Not sure what it is at this point.
I've cleaned the MAF 3 times, checked for leaks and found nothing ( haven't smoked tested, just CARB cleaner ), got fuel I know from good Shell station, Throttle Position Sensors 1 & 2 are both where they need to be ( according to the nGauge ).
About all I can think to do is check fuel pressure/filter quality. I'm hoping I don't have an injector taking a shit but if it is luckily that's easy enough to replace on my own.
RoadCone
Ohio
2016 Competition Orange PP
I know the shop had troubles with Bank to Bank fuel trims once. Dual feed lines into the fuel rails then dual feed to regulator fixed this issue.
brandonalberd
brandonalberd
Dickson, TN
Magnetic S550
Yea I almost wonder if I just went ahead and went with a new fuel system if it would fix my issues, but then again I hate to drop that kinda money and still have problems haha
kcc0521
Falls Church VA
Bo
2015 Black GT PP
There is a cloth filter I believe in the tank protecting the pumps. Do not have any idea what size they filter down to. There is also a conventional canister type quick disconnect under the car.
Only one filter in the tank unless it is a GT 350. The GT does not have an external filter.
brandonalberd
brandonalberd
Dickson, TN
Magnetic S550
I thought this was what I had read. That it was an internal filter. Still, could that be replaced alone, or would that entail replacing the entire fuel pump?
superman07
columbus ohio
2016 gt350
checked the shop manual, and wow, no filter. Sorry for the fake news. I thought for sure it had one but just the 350 does apparently.
brandonalberd
brandonalberd
Dickson, TN
Magnetic S550
So that probably means replacing the entire fuel pump correct?
Tommy V
Brookly park Md
Tommy
I would check pressure first,and if possible drive with the gauge in the car so u can see pressure under looad.
ahl395
Allan
I second this
brandonalberd
brandonalberd
Dickson, TN
Magnetic S550
Gonna go today to AZ or Oreilleys and see if they have the 3/8" fuel line adapter to run a sensor into. I know I can order one, but figure if they have one I can do it faster. I know Lund sells a sensor kit for the nGauge but, it's $100+
ahl395
Allan
brandonalberd
brandonalberd
Dickson, TN
Magnetic S550
brandonalberd
brandonalberd
Dickson, TN
Magnetic S550
Probably buy that CFM piece, or the Nitrous Outlet one. Then find a brass elbow to attach to the fuel sender. That way I can run it 90* back instead of it sticking out.
Marvelous D S550
Tracy
Danny
2015 Mustang GT Magnetic PP
did you find a fix?
