Whipple chrip?
TripleB
Idaho
2015 GT Snack Pack- Whipple Stage 2
Less than a week old kit started having this chrip on startup. Goes away after a while. Guy on Facebook says it’s a bad belt?!? Normal or something to be concerned about?
racingmason
NC
2017 GT Premium
Did you follow the belt alignment instructions?
Whipple SC
Fresno
Go to our website and download the instructions for installing new tensioner. Either the idler plate stands are mixed up or something is misaligned. You can loosen the sc assembly and front plate, if it’s not the stands, that will most likely stop it. You can also inspect the belt, for it to be bad it would have to have a big edge hanging off of it.
angermgmt14
Massachusetts
2016 GT Premium--Oxford White--A6
More than likely a misaligned pulley. Could be the belt too. Not a huge deal, just check pulley alignment. Check out this thread and read Whipple SC replies. (which is also a few threads down in this section)
www.mustang6g.com/forums/showthread.php?t=98135
TripleB
Idaho
Any chance you could please link me? I couldn’t find them on your website? Thank you!
RoadCone
Ohio
2016 Competition Orange PP
I have the rpm belt and when I set the tension tight I didn't have this. I loosened it up some as a previous post states rpm belts break under heavy tentsion.... and now I have the same thing. Goes away in about 5 minutes or so...
TripleB
Idaho
Is the belt that comes with a whipple kit the RPM belt? Thanks
Whipple SC
Fresno
Tension does not break RPM belts, whipping back and forth does. Reapply tension like originally instructed.
RoadCone
Ohio
RoadCone
Ohio
Yes, that's in the ideal range.
Thank you. I added the 10 rib system to my kit and it didn't have specific instructions for belt tension, so if you want to provide more insight, I would appreciate it.
racingmason
NC
2017 GT Premium
My Kenne Bell is set about 85 percent and has a chirp to it until it gets warm. Laser aligned the pulleys and I figured it's just the nature of the belt material. The fleet belts are quiet but the rpm belt is better for the application.
