Whipple 20PSI Boost Vented or Non Vented Catch Can
Autopart101
Joe
2020 GT
Can anyone advise what benefit if any, using a Vented over non Vented Catch Can? Anyone have any data at higher boost levels? 18/20PSI Boost.
Mach1Racer
Everywhere
Mach 1
Vented is generally preferred due to the fact that it will not affect the tune in anyway and allows the pressure from motor to escape freely.
However, vented catch can may produce a smell that is not desirable.
You should ensure that whichever method you use, don’t vent one side and recirculate the other.
Ask Beefcake because he is knowledgeable and sale whatever products you might need for a solution.
UPR might make a dual can but I’m not sure.
https://www.uprproducts.com/15-23-m...gle-valve-oil-catch-can-with-css-plug-n-play/
J17GT
IL
2017 Mustang GT PP
Yes, if boosted vented seems to be the preference. I recently installed a Motion Raceworks vented catch can on my whipple setup. Driving around normally I don’t smell anything. If I’m aggressive with the throttle or go WOT, I do get an odd subtle smell in the car. Smells kind of like a mix of oil and e85. Haha
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
I run a Mighty Mouse vented catch can on my Camaro. It has a Whipple 3.0 at 19 pounds of boost and 1066 WHP. The vented can only pops off if you see any positive crankcase pressure which saves seals from blowing out.
Autopart101
Autopart101
Joe
2020 GT
I run vent to atmosphere on boosted setups.
I just bought Motion Works set up vented. Going to push stock motor on 20psi.
