Whining sound
Zeromaz
Las Vegas
GT350R
I noticed this morning that my GT350R didn’t sound right when i started it up. There is a quiet whining sound. Out of gear at idle it is present and when putting it in gear and going, the pitch of the sound goes up with the RPMs. Anyone have an idea?
Cammer
Portland, OR
2016 Shelby GT350, 2001 F-150 Lightning
Mine whines in the same way when the AC is on so I’m worried about the compressor.
Brian
Austinj427
CO
2017 GT350
Pushing the clutch in makes no difference?
Hack
Minneapolis
Mustang, Challenger
Could be a squeaky bearing from one of the pullies in the front accessory drive.
crazymayhem
Daniel
2017 GT350 LB
Id suggest checking your oil level asap. I had a whining when the car was warm, noticed it when in idle when stopped. Very light throttle made the whine more high pitched. Clutch in made no difference to the whine.
Dr. JL
2016 GT350R: GR227 and GR378
Static/noise due to the faux engine noise pumped in thru the speakers? Did you accomplish the Forscan cockpit noise delete procedure?
Zeromaz
Las Vegas
GT350R
I’m not sure what that is. Could you explain it please?
I’ll check the level when i get a small break at work. I would hope its good considering the dealer just had it last week.
Zeromaz
Las Vegas
GT350R
Hahaha yeah, right? I always get nervous, even at Ford.
Stang 19
Ca
2020 GT500 Ford Performance Blue
:angel::giggle:
Water pump and/or water pump pulley. I’d have to check my records but i’m at work at the moment
?Someone broke in to your garage and installed a blower?
