Which toe rods?
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
Matthewstorm
Matthewstorm
NC
Matthew
Someone... Anyone...
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
Not a lot of people run the full replacement arms because there isn't really a problem to solve with the OEM ones. Replace the bushing with the M-5A460-M bearing and there isn't much left to do.
KellTrac
www.kelltrac.com
All of them
I use the BMR TR005 links on my 2020, and have on my previous (4) S550 Mustangs with absolutely zero issues. @Jaymar is mostly accurate above, but I do my own alignments and despise the factory eccentric adjustment and, I have have the toe adjustment slip on my cars in the past. I prefer the lockouts with the turnbuckle adjustment. 100%
Matthewstorm
Matthewstorm
NC
Matthew
Thanks.
I don't understand your last sentence. Haha.
DougS550
Fishers, Indiana
Doug
Putting together a kit and not sure which one is for me.
https://www.lethalperformance.com/bmr-2015-mustang-double-adjustable-rear-toe-rod-red.html
https://www.lethalperformance.com/w...r-control-arms-2015-2018-mustangs-kta228.html
I just installed the BMR rear adj tie rods. They are very well made and alighned perfectly. I also installed the BMR adj Camber links and installed their camber lock out plates so the camber will never move. Good luck
Thanks for the Help.
Jaymar
Portland, OR
Jaymar
Thanks.
The lockouts lock the factory adjustment mechanism which is what @KellTrac has seen slip under heavy cornering force. The turnbuckle is the new adjustment mechanism on the BMR replacement toe rod.
Matthewstorm
Matthewstorm
NC
Matthew
Thanks!
