Which size r888r?
L8APEX
Nice try NSA
'15 GT, '20 Raptor
I am looking to buy r888r and I intend on tracking the car a lot this summer. My rims are HREs 20x10 and 20x11. What size do you recommend for the track?
strengthrehab
Houston
Ken
2016 DIB Base GT with PP
OOF, 20" tires are going to be expensive to run if you do multiple track days. 285 and 305 are popular in 19x10 and 19x11, but I'm not sure what is available in 20s for the 888R
Ewheels
SoCal
Eric
'18 GT PP1, '23 F150, '24 4Runner Pro
I haven't done the math but it might honestly be cheaper to buy 19s or 18s for the track and corresponding tires. 20 inch track tires will burn a hole in your wallet very quickly.
If you're serious about getting track time, I would advise getting a dedicated set of wheels/tires only for the track anyway. Plus the smaller diameter wheels will weigh less = more benefit
AlbertD
Tucson, AZ
2016 GT/PP
For that tire, you would probably want to take a look at running 285/30 up front and 315/30 out back. You could also run the 285/35 and 305/35 combo, but that will considerably increase tire diameter. I concur with Ewheels... if you plan to track a lot then a dedicated set of either 18s or 19s would be the best option. The tires are quite a bit cheaper... I even went down from 19x11s to 18x11s... saved me almost 500 dollars per season not to mention the added benefits of the smaller diameter wheel.
