Which Lightweight Battery Is Best?
Driveway Demons
www.youtube.com
Corey
2020 GT350
I am thinking about the Braile B129. However I want it to be able to start the car a few times a week and sit in the garage a few days without starting and not completely die. I want it to be trustworthy for driving out of state or vacations I may drive for out of state for a week and don't want to be on the side of the road with a dead battery. These are the two batteries I am looking at below. I also am curious do I have to program the car via FORscan to reset the battery learning?
https://braillebattery.com/products/b129-1
https://antigravitybatteries.com/products/starter-batteries/restart-oem/atx20-hd/
Mjc1241
Georgia
Reese
2016 Shelby GT350
Tomster
Beware of idiots
Tom
Top the Antigravity battery up before installing and you don't have to do a reset either. I'm pleased with mine.... ATX-20HD
zsommer79
beater
I have an extra Shorai LFX36 that I am thinking about trying out. You can pick them up for like $250 so if it works might be a good budget friendly option.
Driveway Demons
Driveway Demons
www.youtube.com
Corey
2020 GT350
You mean put on a slow trickle charge for a few hours at 2-3amps?
Tomster
Beware of idiots
Tom
yes and no. You need a charger designed specifically for a lithium ion battery. I use the Ctek charger that antigravity sells
ReapSow
Colorado
Adam
2017 GT350 and 1996 Cobra
I'm running an Earthx etx900 LiFeP04 and havent had any issues. Battery weighs just under 5 lbs
Driveway Demons
Driveway Demons
www.youtube.com
Corey
2020 GT350
did you have to do the reset?
Driveway Demons
Driveway Demons
www.youtube.com
Corey
2020 GT350
Tomster
Beware of idiots
Tom
The Multi charger I have is below.
https://www.amazon.com/dp/B07BLLRM8R/ref=cm_sw_r_cp_api_i_.TnJEbJ5YAZ08
Also would this work? I would want a mobile charger so on the road I could jump myself if anything happened. Will this work?
https://www.amazon.com/dp/B07GN5HHXJ/ref=cm_sw_r_cp_api_i_YUnJEbA9Q6VZF
If it is compatible with lithium ion batteries it would. The first item looks like it is a conventional battery charger. The second item looks like it is a lithium battery to jumpstart a conventional battery.
Once the battery is charged with a lithium battery charger, you probably wont need it again if you drive your car frequently. If it sits for a while, you should have a battery maintainer that is compatible with lithium batteries.
ReapSow
Colorado
Adam
No I did not. I did install a fully charged battery but nothing special.
Antigravity Batteries
Gardena, CA
Porsche GT3 RS
Hi guys, just wanted to chime in with a couple things to be mindful of and that's hopefully helpful....while technically the multi-chemical composition chargers should work we tend to stay away from them as it's just an easier way to eliminate the possibility of the charger charging with the wrong profile so as Tomster mentioned, a dedicated intelligent lithium charger is ideal. Shorai makes a solid battery by all means but one thing to be aware of is that there are no protections built in, so if the battery does go dead and get over discharged you would not want to attempt to jump start it as that could lead some very bad results. Having protections on the battery in automotive applications is the only way to go in our book. Lastly, in regards to discharging, lithium is great because it does so at such a much slower rate than lead/acid but it's still restricted by a finite amount of capacity. If the vehicle does go with longer duration's of sitting or there are other accessories/aftermarket electronics on the vehicle, going to a larger capacity like the ATX30-HD has can make a huge difference.
Of course as always, feel free to reach out to us with any questions!
-Chad
[email protected]
zsommer79
beater
So if the battery does go dead and get over discharged you would not want to attempt to jump start it as that could lead some very bad results. Having protections on the battery in automotive applications is the only way to go in our book.
I have heard you shouldn't jump start traditional lithium batteries but are you saying the Antigravity batteries can be jump started or that the battery protections prevent it from being drained to a point where that would be necessary?
Gardena, CA
Porsche GT3 RS
Basically you should not jump start an over discharged lithium battery, say, anything under 11v to be safe. The ATX20 and ATX30 HD models have a shut off that doesn't allow the battery to get that low so it would be safe on those models...the full automotive line with regular group sizes go a step further and have a dedicated jump start capacity built in (we'll have a group 26 that should fit most ford application in the coming months)which is even wireless and in addition have some much larger capacity options.
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
This is great info! I have been looking into this as well as HVAC delete. Thanks @Antigravity Batteries for chiming in.
Currently at 3638 on a full tank but wouldn't mind losing more on the car and I wouldn't mind losing a pound or two lol.
