Wheel hop
JimmyTwoTimes
New York
2015 GT Premium
That's not wheel hop though. The "kick out" is different.
I don't get "kick out" either with the S550 because the IRS eliminates "kick out" almost entirely.
Wheel hop occurs when you do anything other than a granny launch on the car. Have you dumped the clutch at anything higher than 2500 rpm? You'll feel it...
I'm only 800 miles in, still doing break-in, so no, but the couple of times I did WOT accelerations before I put on my winter tires I did feel it get slightly squirrely as it lost traction.
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
When I was playing around trying to get 0-60 times I didn't have any issues with wheel hop, just some plain good 'ole spinning depending on what rpm I was launching from. This was on smooth pavement, around 70 degree ambient.
Sl13cobra
2013 GT500
How can it be that the car was designed from the ground up, yet Ford decides not to add a few suspension parts to mitigate it. Blows my mind. I don't understand.
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
Mine hops like crazy on the STREET. Full throttle in 1st or 2nd hops like I am going to break something.
Chargedguard5.0
Dallas
2015 GT
So does mine. I've noticed it's worse with traction control off but still does it with it on as well.
Supa LA
Drop a gear and disappear
So. Indiana
2015 Guard Metallic Mustang GT PP
It does seem worse with traction control on. Could it partially be due to cooler pavement temps right now? Combination, perhaps?
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
Temps absolutely are a big contributing factor in wheel hop. The colder it gets, the more it happens.
Hack
Minneapolis
Mustang, Challenger
Ford puts soft bushings in the suspension so that the ride is nice and compliant and quiet.
You can stop the wheel hop but NVH will increase. Depends on what you want.
Yes the stick axle cars wheel hop too. For the same exact reason.
I see the opposite. When there's better traction, the force from the tires is greater so the bushings in the suspension get deflected more. I guess it depends on if you're calling 60F cold or do you mean 40F... or do you mean -9F like it was here this morning?
foghat
Calgary
2015 GT w/PP
I would think the opposite. No? Colder the pavement = less traction, which should mean less wheel hop.
2snakes
2snakes
OHIO
2014 GT
Does it make a difference if its the stock suspension or the PP that hops
Hack
Minneapolis
Mustang, Challenger
Not sure whether Ford put stiffer bushings in the PP or not. The stiffer springs and shocks could have a slight impact (reduction in hop). I believe that bushings will provide the most improvement, though.
Markbnh1
New Hampshire
Mark
2017 Ford Escape & 2015 Ruby Red GT Premium
What does NVH stand for? Trying to learn the lingo!
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
EcoSwag1990
West Chester, PA
2016 Triple Yellow GT
I feel like this issue is being blown up due to the fact that everyone is getting their car in the dead of winter and half of us are running the PP summer tires. But I do get some wheel hop with my all seasons
2snakes
2snakes
OHIO
2014 GT
CJ Pony says they are coming out with rear control arms to stop the wheel hop
