Got a link to the parts?You can build your own 'stop the hop' kit for like under a hundo haha.
I didn't use the IRS brace, locked it out with the bushings. Wasn't in the list of items that BMR equipped cars in the low 1 second 60' times have. I'd be really happy with a 1.4 60', convertor coming soon hopefully I'll get there.I won't knock BMR but I like the chromemoly better than the mild steel, also steeda's IRS brace looks like it was designed by Ford engineers, and didn't make production due to the bean counters.
Sorry, should prefaced that with "if you have a welder" the it's just a matter of round stock of your choice, gussets, etc which Amazon has in abundance. Or I can make you a set haha.Got a link to the parts?
It works well for me.Was planning on going tomorrow night to try the 2nd gear leave, but had something come up; won't be until probably next month now. Should have the converter by then. I've thought about short shifting 1st as well as go in S mode, then let it shift at WOT from then on.
This is exactly the approach I took when I had the spinning 1st to 2nd issue. I already knew my burnout was on point. (Years of practice & a pyrometer). I took the car to a shop and got a drag racing alignment. Zero back. -2 front. And after that didn’t work. I replaced the nitto Nto5r’s with MT e/t Street R’s. It was the tires all along.I wouldnt throw any more suspension at it. I would make sure your alignment is on point specifically rear camber is close to 0. If alignment is good and burnout proper then its time to go ET street R.
I have the BMR cradle lockout kit and vertical links. Hopped like a rabbit on the 1-2 shift until I put on a set of ET street Rs.
Hey Jerry! Yes, a relay was bad that prevented the intercooler pump from running. However, I no longer have the Mustang. I just didn't drive it enough to make sense keeping it. Besides, I had it 3 1/2 years and sold it for what it cost me when it was new. Crazy used car market!Heh Bruce , just joined , Its jerry , from Coon rapids , Black gt cs . Did you sort out supercharger intercooler problems?
