wheel hop on 1-2 shift, what can I do to fix it?
andrewtac
TX
mark
F250. 2020 GT 400A
I won't knock BMR but I like the chromemoly better than the mild steel, also steeda's IRS brace looks like it was designed by Ford engineers, and didn't make production due to the bean counters.
I didn't use the IRS brace, locked it out with the bushings. Wasn't in the list of items that BMR equipped cars in the low 1 second 60' times have. I'd be really happy with a 1.4 60', convertor coming soon hopefully I'll get there.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
Got a link to the parts?
Sorry, should prefaced that with "if you have a welder" the it's just a matter of round stock of your choice, gussets, etc which Amazon has in abundance. Or I can make you a set haha.
SolarFlare
S. Fla
2015 CO GT
I wouldnt throw any more suspension at it. I would make sure your alignment is on point specifically rear camber is close to 0. Possible you could be underheating or overheating the tires? If alignment is good and burnout proper then its time to go ET street R.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
I learned to short shift second on the street with the paddles to eliminate the craziness with the 1-2 shift at WOT under boost. Launches really good in first with my P1X/3.55's (better than starting in second) and just a nice screech out of the NT555RII's instead of a full dance. As soon as I see the tach pass 4,000 I pull the upshift paddle, and it shifts between 5,000-6,000RPM to second, then slip the shifter into drive.
andrewtac
TX
mark
F250. 2020 GT 400A
Was planning on going tomorrow night to try the 2nd gear leave, but had something come up; won't be until probably next month now. Should have the converter by then. I've thought about short shifting 1st as well as go in S mode, then let it shift at WOT from then on.
LSchicago
Illinois
Lloyd
It works well for me.
SolarFlare
S. Fla
2015 CO GT
It would have to be a very bad prep for a 2nd gear to be better than 1st on a stock converter 800whp mustang.
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
I wouldnt throw any more suspension at it. I would make sure your alignment is on point specifically rear camber is close to 0. If alignment is good and burnout proper then its time to go ET street R.
This is exactly the approach I took when I had the spinning 1st to 2nd issue. I already knew my burnout was on point. (Years of practice & a pyrometer). I took the car to a shop and got a drag racing alignment. Zero back. -2 front. And after that didn’t work. I replaced the nitto Nto5r’s with MT e/t Street R’s. It was the tires all along.
mustang jerry
mn
jerry
2015 f150, 2019 edge st, 2020 mustang gt,
Heh Bruce , just joined , Its jerry , from Coon rapids , Black gt cs . Did you sort out supercharger intercooler problems?
brucelinc
MN
Bruce
2018 Mustang GT premium A10 (SOLD)
Hey Jerry! Yes, a relay was bad that prevented the intercooler pump from running. However, I no longer have the Mustang. I just didn't drive it enough to make sense keeping it. Besides, I had it 3 1/2 years and sold it for what it cost me when it was new. Crazy used car market!
LSchicago
Illinois
Lloyd
315/50/17 ET Street R's solved the 1-2 shift spinning for me.
andrewtac
TX
mark
F250. 2020 GT 400A
