What's the normal air/fuel ratio?
javierhe
San Jose, CA
Javier
2015 Mustang GT, 2020 Raptor, 2022 Mach-e GTPE
Can someone tell me what's the usual air/fuel ratio for the voodoo? I'm trying to diagnose an engine light and would like to have more information...
In my GT, it is usually around 14.0 when idle. But in the 350, I'm seeing it around 10.0 all the time, and I'm not sure if that's normal.
Thanks.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Do you have an E85 tune in the Shelby?
If not it should hover around 14.0 just like the GT
javierhe
javierhe
San Jose, CA
Javier
Thanks @K4fxd . Yes, it was on E85 before. I flashed it back to stock tune and using 91 octane now, but somehow there must be some values still stuck as E85.
SheepDog
Colorado
Dax
Try reflashing your Gasoline tune/ OEM. Air/fuel ratio is not a function of motor type, vehicle type, but a function of fuel type. Any internal combustion engine running on gasoline should target 14.7-1 at idle, but this can change depending on altitude and ethanol content. If you are seeing 10.0 on the cluster, your tune is still trying to achieve stoich. for E85
