What's the difference between these sway bars?
BluePonyGT
Seattle, WA
Corey
2017 Grabber Blue GT Premium 6MT
gqllc007
Albany NY
2017 GT Premium Convertible
I can't help with those but I just Eibach front and rear sway bars installed in the middle position and I am very happy with their performance over stock. Much less body roll and flatter cornering. I traded my 06 Porsche boxster for the 17 Mustang so I was prepared for driving boat compared to the boxster LOL The Eibach helped...it's no boxster but at least it's not a Cadillac now.
I did not lower or change any other parts of my suspension
Nagare
Ft Lauderdale
2017 Lightning Blue V6
The drag one is fixed and presumably a touch lighter, the other is adjustable.
The Ford Performance one is thinner and non-adjustable as well. I think that one you linked for FP is the Street one which is equal to what comes on a Performance Pack car.
tj@steeda
Timothy
We can recommend a swaybar based on your goals - for the Steeda swaybars listed above, Our standard rear swaybar is up to 2.4 times stiffer than stock and the drag bar is 3x stiffer than stock.
Shoot me your contact info & we'll get you dialed-in.
TJ
BluePonyGT
BluePonyGT
Seattle, WA
Corey
Thought so on the Ford Performance option. I'm in a non-PP Premium GT, so that would be a step up, but not by much.
BluePonyGT
BluePonyGT
Seattle, WA
Corey
TJ
PM sent!
I'm simply trying to improve the handling of the car. Wheels/tires are on the way, as well as PP stiffening components I'm missing in the front, but I'm concerned about the IRS and rear subframe alignment as well as the understeer in the car. Wheel hop, any lateral movement in the rear and oversteer are the issues I'm thinking about.
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
I recommend getting adjustable bars for both front and rear on a base; you can really stiffen things up considering you’re current springs. If, down the road, you go for stiffer coil springs you can easily dial-back your swaybar tension and have the Goldilocks effect: just right.
Steeda bars are hands-down the best built pieces on the market for a multitude of performance-related and build-quality reasons. Stick with them.
Dr. Norts
Ontario, Canada
2015 Race Red Mustang GT
Those sway bars he linked come in the Ford performance track handling pack and are stiffer than the PP bars. The PP / street handling pack sways are the same and are black.
Track ones are blue like the Link. Also the blue track ones have no stops on the front sway bar. You'll need yo get some clamp on ones.
VinnAY
Kansas City
18 Camaro 1SS/1LE
I use the Steeda drag bar on my PP and I really honestly considered how many times I'm going to jack that thing up and pull the wheels and try settings on other bars and my answer was I wasn't going to do that. So drag bar it was. I couldn't be happier with it along with my other Steeda goodies that greatly improved this car's handling.
tj@steeda
Timothy
Vinnay!... thank you, my friend, for your feedback!
BluePonyGT
BluePonyGT
Seattle, WA
Corey
Wow awesome info.
Since I’m starting out with a non-PP GT Premium I’m really starting under water so to speak on the handling anyway. The ford performance street sway bars would actually be a step up for me.
Not that I’d take that approach, but it sounds like simply getting a rear sway bar isn’t a good plan. I’d have to get a front and back.
What about links? Can I stick with the stock ones?
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Stock endlinks work pretty well in the rear.
The front endlinks tend to bend pretty quickly. They don't bend much so IDK how much it matters, but yeah, I'd do the front endlinks.
If you want to use a mildly increased rear swaybar to dial out some understeer, that works fine. I'd recommend the Strano rear bar for that because its less stiff than most aftermarket rear bars, and won't overpower the stock front bar as much. However if you're trying to use swaybars to dial out body roll, then you'll want to upgrade both bars so you can keep the handling relatively neutral. Doing too much only on one end of the car will cause too much bias to understeer (if stiff front bar) or oversteer (if stiff rear bar).
Bonefish
FKNGFST
17 Shelby GT350 TY
So what is what is the actual size of the PP sway bars? Trying to compare as I was looking at the BMR ones and Steeda. If PP are similar size then what’s the real advantage?
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
I have the Ford Performance bars (3rd) with the Steeda Pro-action shocks/struts and the car is quiet and handles well. Fairly flat. The Ford Perfromance bars use oem style rubber bushings, not prothane or poly. They are quiet which was important to me. They are fairly stiff. You will need to change the struts/shocks to avoid a squirmy feeling, though.
BluePonyGT
BluePonyGT
Seattle, WA
Corey
Thanks for that. Yep, I dumped the idea of just replacing the rear. I'll have to save my pennies and replace both, and I'll probably replace the links front/back because I'm OCD that way.
