Whats best water stain remover on glass?
monte87
NY-SHITTY
Anthony
2021 Rapid RED Metallic GT
Hi guys,
What is the best water stain remover for glass on our cars?? I parked outside near sprinklers and stained all my windows..
Thanks, Anthony
NGOT8R
Adrian
2019 Bullitt
Try some Dawn dishwashing liquid, white vinegar and water. You might also have to hit it with some polishing compound afterward (wipe with microfiber towel) and follow that up with Windex.
DFB5.0
Australia
Mustang GT Fastback
A couple of ways to tackle this.
First, try a water-spot remover like CarPro Spotless or a 50/50 mix of white vinegar and distilled water. These products are worth having on hand for speedy removal of these mineral etchings.
CARPRO Spotless 2.0 Water Spot Remover 500ml (17oz) *New* - Sky's The Limit Car Care (carpro-us.com)
CARPRO Spotless 2.0 Water Spot Remover 500 ml. (autogeek.net)
If that doesn't work, you will need to polish them out. Use either a heavy cutting compound (glass is hard and can take more aggressive compounds) or use CarPro CeriGlass. Use by hand or machine.
CeriGlass can be bought as kit or a single item. The kit is better value and comes with a small applicator pad. On a machine, use a Rayon Pad.
CARPRO CeriGlass Polish Kit (150ml) - Sky's The Limit Car Care (carpro-us.com)
CARPRO CeriGlass Polish 150ml (5oz) - Sky's The Limit Car Care (carpro-us.com)
CARPRO Glass Rayon Polishing Pad - 5" - Sky's The Limit Car Care (carpro-us.com)
CARPRO Glass Rayon Polishing Pad - 3" - Sky's The Limit Car Care (carpro-us.com)
monte87
monte87
NY-SHITTY
Anthony
Thanks for reply
monte87
monte87
NY-SHITTY
Anthony
Thanks for reply. I hope these stains come out, they look horrible.
QUOTE="DFB5.0, post: 3551603, member: 29348"]
[/QUOTE]
Ecto1
Rick
2015 Ecoboost Premium
If vinegar & soap solution doesn't work try Chemical Guys Water Spot Remover. It is AMAZING on water spots. Needed to get rid of some on my 02 TBird and tried everything short of a mechanical buffer and rubbing compound. The Chemical Guys stuff works. Easy to use with no residue. No damage to paint, chrome, or glass. Received mine 2 days after ordering. Great product, great service.
https://www.chemicalguys.com/heavy-duty-water-spot-remover/water-spot-remover.html
The 4 oz bottle should be all you need.
Aftrmat
Fresno ca
Alexander
2021 mustang gt
Hi guys,
Thanks, Anthony
i use chemical guys water spot remover with amazing resultsand easy to use and clean.
DFB5.0
Australia
Mustang GT Fastback
Hmmm...I'll have to check to see D, but my guess is I have V1 and probably have half a liter left.
I have the older version too. I don't use it often, more of an insurance policy, so I wont need to get the newer formulation for a LONG time. Was curious as to whether the V2.0 is noticeable better.
ay1820
Connecticut
Al
2020 GT/CS
I recently had the same question. I ended up using Zaino glass polish which worked well for me. https://www.zainostore.com/product/Z-12.html
I got a lot of great suggestions here, but I had a very old (like at least 7 or 8 years old) bottle of this stuff in my garage, so I figured I would give it a try and it worked great.
