What is this intermittent sound?
mookieit
tampa
john
mustang 2015 v6
I have been having this sound for a long time and was wondering what it is.
notice the sound in the video , when the sound happens the boost gauge changes.
This happens when i turn on the heat or ac and the sound repeats every like 10 seconds
ORRadtech
Atlanta, Georgia
My first thought was the AC compressor cycling on/off. It fits the symptoms but it's really hard to tell from that clip.
Have you watched/listened to the engine with the hood up? Probably easier to localize it that way.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Cant tell from the video really but the repeated sound every 10 seconds sounds like AC compressor cycling to me as Dave says above ^.
Probably have the AC switch on when the heater is turned on which causes the compressor to run as well.
I bet if you turn off the AC button it wont do it.
ORRadtech
Atlanta, Georgia
If the climate control is in auto mode it can, and will, use the ac compressor whenever it thinks it needs the defroster. In fact, anytime you use the front defrost, manual or automatic, the ac compressor is used regardlessofthetemp setting. It blows dehumifid are on the windscreen to help clear moisture.
PoCoBob
Port Coquitlam B.C.
Bob
2019 Mustang GT Premium, 2016 Edge Sport
If it is the a/c compressor and it's cycling on and off every 10 seconds there's a good chance the the refrigerant is low. You may want to have that looked into.
jloshotz
NY
Jack
2016 GT Premium
Could just be the HVAC blend doors cycling too, if it’s most prominent while in the cabin. Just a thought 👍🏻
mookieit
mookieit
tampa
john
mustang 2015 v6
The pressure is not stable, what do you think?
PoCoBob
Port Coquitlam B.C.
Bob
I'm not the guy who could answer that. All I know is I had an F150 that needed to have the a/c recharged every 3 or 4 years and the tell tale sign was when the compressor was kicking on and off like that. If it's low you shouldn't be getting much cold air coming out of the vents inside the car.
mookieit
mookieit
tampa
john
mustang 2015 v6
Thank you for sharing
ORRadtech
Atlanta, Georgia
The pressure will fluctuate a little bit. The thing is, that freebie guage isn't really worth much more than it cost.
But what concerns me more is the noise the clutch seems to be making. Then again, it's hard to tell in a video exactly where the noise is coming from. It could be a tensioner or pulley that doesn't like the extra load.
If it is the compressor/clutch you really need to hook a set of manifold guages to the car to look at both the high and low side.
At this point I'd suggest taking the car to a trusted mechanic and have them check the whole system. They can discharge and weigh the refrigerant in the car and, if nothing is wrong, recharge it with the correct amount of refrigerant.
I'll also add that if the compressor is trying to grenade you may be looking at a fairly expensive repair. That's because, for any new compressor warranty to be valid, they often require several parts of the system to be replaced. Parts like the condenser, expansion valve, flushing the evaporator, etc because of the possibility of shrapnel in the parts.
Similar threads
