What fuel do you use in your GT?
V8 WUU
Bristol - UK
Mustang GT
I only ever used 95 in my 2017 GT, however since getting my 2021 GT from new - i thought i would try using 99.
I started off with Tesco Momentum, which i have read good things about, and is a good bit cheaper than V power.
However i just tried a tank of V-power, and i swear it picks up better at low RPM and feels smoother?
I guess it could be placebo effect.
What do you guys use?
maddog1982
UK
Mustang GT (S550)
I only use 99 mostly vpower until it jumped up 20p a litre in about a month. On momentum now. Using vpower it pulls better in 6th from 60 than regular 95. Takes a few tanks for the timing to adjust i believe.
GR11M
Herts, England
Graham
Ford Mustang GT
I use V-Power, will it be affected by the move to E10 ?
NGOT8R
Adrian
2019 Bullitt
I like that E in my Stang. It burns cleaner, cooler and helps make more power.
hinch
uk
Sideways
i'm tuned to only run on 97 + octane booster :crackup:
rcald
Port Saint Lucie, Fl
Randy
2020 Bullitt L3483 2002 Mustang GT Convertible
US 93
raptor17GT
Scotland
Mustang GT Manual 2017
yeah SUL all the way, if i had zero fuel and only 95RON then fine would put enough in to get to next garage.
Likewise i understand E10 only for unleaded 95RON
Tim_
UK
Lightning blue S550 Coyote convertible
Super unleaded is remaining at E5 but the E10 stuff would work ok in the S550's, just don't leave it sat in the tank for long periods of time or it'll absorb water.
Shell V-Power here, definitely runs better. I only bung in 95 when I have to.
WD Pro
United Kingdom
Lime GT
Since Shell launched Optimax (now V-Power) I haven't used anything else in my cars - so I now have one on V-Power diesel and one on V-Power petrol.
Only car in my household that gets anything other than V-Power is my other half's Picanto, that 66bhp of turbocharged madness doesn't need any special fuel to kick arse ... :cwl:
WD :like:
Kristian87
Super Moderator
Moderator
Newbury, UK
Mustang GT
I'm kind of keen to try this. I live literally opposite a shell garage so seems rude not to!
I've only ever used regular, and I'm 32K+ miles in. Not doing so much driving these days so may go for vpower on my next full tank, and report back.
Gregs24
Wiltshire UK & Charente FR
Greg
Mustang V8 GT, Ford Kuga PHEV
Esso Synergy Supreme 99RON is ethanol free except in Devon, Cornwall and Scotland / NW England. It is labelled E5 on the pump still.
You need a few tanks of higher octane fuel for the ECU to make the most of it
GR11M
Herts, England
Graham
Ford Mustang GT
I have a flex tune if they ever decide to bring back E85 :like:
Tim_
UK
You'll need to give it a few tanks to run out the old stuff and let the map switch to the new fuel. I find the biggest noticeable difference is not going from 95RON to 99RON but running 99 for several tanks then going back to 95.
According to the dash read out my fuel economy has also improved with 99RON which negates some of the cost increase. Even then it's only an extra ÂŁ1/100 miles or something to run 99RON.
