Inthehighdesert
Make it 3. With all the work ur doing Id fab up some sheetmetal or thin plate stock to go from the jacking rails to the unibody rail. Thats a pretty vulnerable area for that cable. Cool build though.
Or add an car audio specific battery to the trunk. Like a GEL cell.If you need that much power in your trunk for two seperate 1/0 runs, then you'd probably be better off relocating your battery instead.
Thanks man! Good to hear about the tires! I have been meaning to make it out to Laguna but haven't quite worked it out yet.Good to hear! I like the look! I have HRE FF04's with the same tires and size with the exception of the rears being NO Porsche and not K1. I know you were wanting to know how the NO Porsche tires performed. I recently went to Laguna Seca and the tires performed extremely well.
I'm on RideTech coilovers with higher spring rates geared more for track use. One thing I noticed when I did my post track inspection and bolt torque checks afterwards was that the taller than stock tires both front and rear were coming in contact with the bottom of the wheel wells. You could see the outline of the tread on the bottom of the wells with exception to the left rear. Laguna Seca does have some corners where you get some good compression at speed compared to some of the other tracks I've run.
Fortunately I have a set of 305/30R19 Continental ContiForceContacts in the garage waiting for some dedicated 19x11 track wheels. They are much shorter so I don't anticipate the same issues.
Two Rockford T2500-1bdcps, T600-4, P400X4, Helix DSP ProWhat are you powering with cables that huge?
Not sure that's how I would have run those cables........
I wasn't sure for awhile either. A good couple hours was spent just figuring out the best route to take I think. Originally looked into routing over the differential but was much more cramped and hard to get above moving parts. Through the wheel wells worked best.I second that!
Thanks, that's not a bad idea I may look into that. The conduit is pretty tough but it is only plastic.Make it 3. With all the work ur doing Id fab up some sheetmetal or thin plate stock to go from the jacking rails to the unibody rail. Thats a pretty vulnerable area for that cable. Cool build though.
An XS Power D4700 is going up front and a D3100 is going in the rear. Car audio AGM batteries. The D3100 is huge and around 90lbs. Both capable of alot of amperage.Or add an car audio specific battery to the trunk. Like a GEL cell.
Thanks :lol:Dumb
Nice, Dirtyblueshirt. My sister has a stock 2016 Ecoboost that I've driven and those puppies are quick, especially down low. You upped your game. Congrats on the successful mods. :cheers:Got my car on the Dyno today. 314 rwhp / 377 lb ft torque. Solid increase of about 20hp and 50 lb ft from the Roush CAI and Magnaflow exhaust alone. It puts me (at the wheels) above the advertised specs at the crank, and (based on SCT's test of a stock EcoBoost) +83hp and +89 lb ft greater than stock at the wheels.
Not record breaking by any stretch, but It makes me happy.
Hahaha :lol: that made me laugh. 750 amps worth of cable!He's building a Pri-mus! I seen smaller cables working on a Prius! Damn that is some wire. :lol:
