What can cause this? Backwards brake pads?
Metz3020827
Arizona
Connor
2017 Mustang GT
Just looked at my rear rotors and they’re like rusted where the pads are I’m assuming meaning the brake pads are maybe backwards from when I replaced my thrust washer last week? What do yall think?
Pistol_91
Clearwater
2020 mustang GT
I have 1 rotor in the rear that looks similar to this one. I think it's just junk material.
shogun32
Northern VA
maybe post a pic of the rear caliper/pads as they sit?
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Pull the wheel off, pull the pads. Inspect.
luc
CA
2017 GT with PP
Backwards?
Hell no, if they were the metal grinding noise would be so obvious that you would know right away
C-WOODS-70
Illinois
'65 A-Code coupe, '67 A-Code coupe, '22 GT PP 6MT
That's what happens when the brake lining material wears down and it becomes metal to metal. The brake pad metal backing is what is stopping you now.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
Brake pads still have plenty of life believe it or not lol. Not even close to being worn out. Definitely not the problem haha
luc
CA
2017 GT with PP
Have you ever heard the noise than backing plate make on a rotor ?
Furthermore would be a lot of silvery metal dust/debris
So wrong diagnosis
C-WOODS-70
Illinois
I've seen rotors that look worse than the picture above due to worn out pads and the driver had no idea there was a problem. As a mechanic in my earlier days I seen this with my own eyes.
C-WOODS-70
Illinois
I also did not see the text under the big picture in the original post. For some reason I always look at the top. I guess you would have caught worn out brake pads when you had it apart.
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
is that pad unevenly worn on that top portion?
sk47
North Eastern TN
Jeff
Hello; I get this will not apply directly to a Ford. Have had a similar pattern on the rear rotors of a chevy pickup for a couple of decades. The outside pad will wear more on one place. There will be a shinny circle maybe an inch wide with a duller surface on either side. The inner surface of the rotors will be shinny all over. The pads will wear faster on the inside than the outside.
My rear calipers are the single piston floating type. I tried different things over the years. Mostly making sure pins and other places where the calipers move are clean and lubricated.
Couple of years ago I put on two new rear calipers. Both rotors look better now but one side is slowly going back to the old pattern.
I figure it is a built-in problem from the factory as i have seen other trucks the same way.
