Best brake pads
Xzavior1818
ohio
Anthony
2015 SCION xB, 2019 Mustang Gt
Yeah with the powerstop z26s I paired the raybestos S slotted rotors to help increase brake performance. The dust is also night and day compared to stock.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
The OEM stock pads are great for a street car that gets driven hard. Based on the OP's description that's what I'd do.
The ONLY downsides to them are the dust and they aren't up for hard track use. For most novices, on track they're fine.
CrazyHippie
Michigan
Craig
2023 Mustang GT/CS
Those are unique rotors and look really cool. Typically, with dimpled rotors, there's a substantial increase in brake noise due to air getting trapped in the dimple as it moves across the brake pad, heating up and then popping when it clears the pad. Are your rotors noisy?
Xzavior1818
ohio
Anthony
Honestly I can't tell a difference in sound compared to stock. Wouldn't the rotor rotation velocity play a factor in that? Never heard of that before. Figured slotted rotors are for better bite because they clean the pads on every swipe. In addition to "slightly" more surface area to cool. But they do look cool. Almost looks like a 2 piece with the black hat.
PVAMT
Raleigh NC
Pete
2016 GTPP Deep impact blue / silver stripes, red pinstripes
I tried searching for any related post about brake pads but couldn’t find anything. I’m looking at break pads for a 2020 PP1 Mustang GT. I keep seeing powerstop Z23 and Z26. I was wondering which one was best. I don't daily the car but when I do drive it I'm pretty throttle heavy. I don't track the car expect for the occasional race the po po event at the local drag strip. Tons of spirited driving but once again, hardly any track time. Which one should I go for? Thanks in advance
I put Hawk 5.0 on the front with turned rotors. They make way less dust then the Brembo ones did and stop on par if not better. It was worth it for the reduction in brake dust alone.
Nickel
NC Twisties
www.instagram.com
Nick
2022 Mach 1 Handling Package TR3160 w/Recaros
Happy to see no one here has found my secret weapon pads yet, so I'll just let y'all wander and keep using powerstops.
S550HPP
PDC
2022 HPP Vert
I just bought Ford OE pads the rears are made in Italy and fronts in MX. Have no reason to change to save a few dollars they work great and rotors are near new at 49000 miles.
CrazyHippie
Michigan
Craig
2023 Mustang GT/CS
I promise that I won't tell anyone - you can trust me with your secret weapon.
Midnight Menace
Pennsylvania
2016 mustang gt premium
I'd go hawk 5.0 pads if it was me. I've used them for years. Tried powerstop on the most recent change and they suck in comparison. Braking power isn't as good and they are noisy. The only issue with the hawk pads is they stop so good if your not easy on the brake rolling to a stop sign you will jerk your passanger around.
What powerstop pads did you have? Powerstop pads are dead quiet. You can't hear them at all and they don't dust. The hawk pads are pretty noisy and they dust much worse. Z23 and z26 make 0 noise maybe you got a bad batch or you installed them wrong or you are confusing them with the hawk pads. I've tried the hawk pads and they are maybe 75-80% as good as the powerstops and wear out much sooner than powerstops.
NightmareMoon
Hawk dust can do a number on your wheel finish too.
Zrussian13
Phoenix
The hawks were dead silent always. My powerstops are loud as shit. They have got a little better over time but still suck. The hawks out stop the powerstops all day everyday, probably why they do produce more dust. That's the only thing powerstop wins at.
I ran the hawk pads with stock pp1 rotors and bought the powerstop z26 pads and rotors as a kit so I might have liked the pads better with the pp1 rotors but powerstop sucks in my opinion.
Midnight Menace
Pennsylvania
Very interesting. I've run powerstop on all my cars as do dozens of others I know and they are all dead quiet. I have the exact opposite experience as you (and so do everyone else I know in person who have actually tried both brands) it's always been hawk is noisy, powerstop is quiet and the powerstop out stop the hawk all day long. But you seem to have the opposite experience. It is genuinely interesting that people can have such wildly different things. I assume it was either a bad batch of powerstops or a improper bed in procedure because I've never heard of 1 single case of powerstops being noisy not in my over 300k miles of usage or from anyone else. Also powerstops can outbrake my 275 tires so there is no better braking pad (I mean track pads will obviously stop better but that's only if I go to stickier tires and wider tires to get better grip). If you can hit the brakes hard and lock up the tires then the brakes are stronger than the traction and you need better tires not better brakes
Coyotebawl
Lafayette, Louisiana
2019 Mustang gt
I started using Akebono ProACT® Ultra-Premium Ceramic Brake Pads a few years ago and have been very pleased with them as far as performance and low dusting in a street daily driver situation.
barron64
Auburn, AL
2018 Mustang GT convertible PP1, 6sp, 2006 Toyota Tundra Dbl Cab 4x4, 2009 Acura MDX, 2007 Toyota FJ Cruiser
Stock PP1 pads worked well but are a dust storm under hard street use or a track day. Also damn pricy btw. Tried some EBC Yellow pads which worked well but they squealed like a pig all of the time. Ended up trying a set of Powerstop Z26 pads which were very cost effective, and perform very well. No dust and good feel and bite.
