Well that went bad
tcman54
Stanghead
Palm Coast, FL
Terry
2016 Ecoboost
2 words: CHUCK NORRIS
pitmanr2003
usa
2015 Mustang GT Premium Convertible
I'm seriously thinking I may need to drill it out a bit to see if I can get it to break loose. What do you all think
pitmanr2003
usa
Or is there away to get the shift shaft off so I can push out other way.
pitmanr2003
usa
I did that. That's how I actually got it to move to where it is now. That isn't working to get it further.
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
I say glue something to the top of the white cylinder and then pull it out. Put tape around so you can control the glue from getting all over.
pitmanr2003
usa
Yeah I tried that.
pitmanr2003
usa
Use an epoxy base glue, crazy glue doesnt work
Ok I almost bought that but was scared it would make worse. I used plain gorilla glue. I will try epoxy based gorilla glue. It was was a 2 part. So when you say tape it up I'm confused. Do I put tape around nail head? It's to tight to get tape inside whole I think
Geosh
Gilbert AZ
Josh
2019 Mustang GT
Use an epoxy base glue, crazy glue doesnt work. Once it crystallizes it looses its holding power
I’d be very hesitant to use a glue. It’s a fairly tight fit and any glue that wicks down between the tube wall and the plastic piece is just going to glue it in place and cause more problems.
I think the drilling idea isn’t a bad one though and a lot less that could go wrong.
Slopoke
Left Coast.
Ed
2019 Mustang GT PP1 10R80
Drill a hole and use a screw insert a long wood screw, then pull.
pitmanr2003
usa
I'm thinking of taking small drill bit and drill down a bit. Then. Screw a slightly bigger screw in and pull out. Or a bit more risky would be to use a drill bit smaller that metal and drill down little bit at time pulling bits of plastic out. Then try to use the two holes to slide up like mentioned above
EmCel
VA
Em
2016 mustang gt
Try it now and let us know how that goes đź‘€
