Isn’t the PP1 typically 12.1 ish?Not any better than 2018 PP1 time. But it is a solid 11 second stock hot rod.
Lee
11.9-12.1 depends on track/weather ect. average driver is probably 12.1-12.3.Isn’t the PP1 typically 12.1 ish?
tesla had 2 motors, not fair.
Interesting and thanks
That actually kind of makes since. Both car torq value is 420. So ets should be really close but the Mach with 20 extra HP should trap a higher speed.Only the HP has better tires. My 2018 had the same size cup 4s. The A10 cars in good air are high 11 cars.
Less than that. A guy with good rubber has gone 11.9 in a stock Bullitt. Mach1's better gearing average driver should be around 12.3-4 probably, better ones probably 12.0-12.1.No bad! So, us stick guys can anticipate a second slower?
Don't forget the other negative of more weight(coolers) and I'm sure the wider wheels are heavier. Not enough to offset the gains, but just pointing them out.With the no-lift shifting, better gearing and suspension, should be better than a Bullitt...can't wait to see
Dumb coolers...Don't forget the other negative of more weight(coolers) and I'm sure the wider wheels are heavier. Not enough to offset the gains, but just pointing them out.
